It is currently Sat Jun 21, 2025 5:52 pm
 Post subject: Rear Van Subframe
PostPosted: Sun Jan 09, 2005 5:45 pm
Is the rear subframe on the van different to a car? If so has anyone got one they want to sell?
Chris
Everything I like is either
PostPosted: Sun Jan 09, 2005 5:53 pm
No difference...
only handbrake cables are longer on a van
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Jan 09, 2005 5:54 pm
as far as i am aware they are the same as normal sedan ones, the dampers are different though, they are slightly longer to reach the mounting point.
aaron
PostPosted: Sun Jan 09, 2005 6:14 pm
aaron
30mm to be precise. It's hard to get new van shocks, but you can put sedan ones in, thats what I did with my van.
PostPosted: Sun Jan 09, 2005 7:46 pm
The trumpet (fits between the arm and cone) on a van rear subframe is a few mm longer and has a slightly different foot where it fits into the cone. This is to stiffen the rear end slightly and cope with a full load. Same trumpet is used on a Moke.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Jan 09, 2005 8:32 pm
Thanks fellas. The rear subframe I was given for the van is very rusty. I can't be bothered trying to fix it. I'll have a bit of a look around for rear dampers.
Chris
PostPosted: Sun Jan 09, 2005 9:03 pm
Just put sedan shockers in...
unless your planning on carrying heavy loads around.
PostPosted: Sun Jan 09, 2005 9:39 pm
It will be loaded, just depends on what is meant by heavy loads. What is the load rating of a van?
Chris
PostPosted: Sun Jan 09, 2005 9:44 pm
I have sedan shocks in my vans and ute...
And they carry around a lot of crap.
hasn't hurt them. you may find they wear out a little faster but most times they
last longer than the owner
PostPosted: Sun Jan 09, 2005 10:14 pm
I did not notice any differace in mine at all...even with the Hilo's (copies) I put in. They still had the Wet hole in them also
