It is currently Tue Jul 22, 2025 1:58 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Mon Nov 12, 2007 11:42 pm
smac wrote:
Mick, the Doc had experience with one with way too much run-out. Other than that I've heard nothing other than "my mate knew someone who met a guy..."
Matt- what was superior?
Mini spares one was out of round, bent, with a crooked ringear welded on. & even when balanced caused a bad vibration. A friend is now using it with not too much problem, he has some vibration though.
MED workmanship was superior, the flywheel couldn't be faulted, it was quite literally perfect!
Mini Spares came to the party with a refund without returning it, even though i didn't get it through them, i got it from adelaide (who refused to consider a refund :roll: )
Matt
PostPosted: Tue Nov 13, 2007 12:10 am
Interestingly enough when I was having my crank assembly balanced at MED, steve told me it was one of there flywheels. I mentioned it was purchased from Minispares in the early 80's. As it turns out MED used to supply spares, Only problem I had was it pulling up the taper, which has been sorted out as explained earlier.
There is no run out on mine.
