It is currently Sun Jun 22, 2025 7:45 pm
 Post subject: rear brakes
PostPosted: Mon Jan 10, 2005 8:20 am
hi peoples
i have been trying to no avail to get my handbrake working. the cords pull but nothing happens down the other end??? :( what could be the problem? is it something to do with fluid or what?
any help would be great
sean
Potato
PostPosted: Mon Jan 10, 2005 9:04 am
No it's a mechanical linkage in each drum..
Check the quadrants on the trailing arms are free to move, maybe the pivot pins in the rear brakes are jammed. If so give 'em a bath then free them up! :wink:
PostPosted: Mon Jan 10, 2005 9:07 am
Have you also adjusted the drums at the backing plate.
Cable could have streched
 Post subject: Handbrake
Does it feel like there is any resistance there when you operate the lever??
Check the adjustment of the cables......
Check the levers on the rear Brake Backing Plates ....are the ends of the brake cables even connected!! are the levers all frozen up (pull the cable or try to move the levers at the backing plate)
Check (with a helper) with one drum off that the shoes are moving outward when the lever is pulled
However, sounds to me like your rear brakes are probably just worn down too low or are not correctly adjusted
[EDIT: Doc, Gaf...dunno what happened there...me no like being echo man!! when I posted there was nuttin there :? ]
Users browsing this forum: Goldbrocade_62 and 104 guests
