It is currently Thu Aug 21, 2025 5:32 pm
PostPosted: Tue Nov 13, 2007 11:50 am
I'd like to know what needs to be done to fit the airconditioning unit from a late rover mini into an early aussie built roundnose mini...
I've seen the setup in plenty of rovers, but never in an aussie roundnose.
I know the compressor needs to take the place of the alternator, so the alternator needs to be relocated, what bracketry is required?
does the front apron need to be modified to fit the condensor?
what holes need to be drilled into the firewall?
what else needs to be done?
the bits'n'bobs that need to be fitted look like this (thanks Brett - his setup is for sale http://www.ausmini.com/forums/viewtopic.php?t=37007)
PostPosted: Tue Nov 13, 2007 11:59 am
i don't think you need to drill into the firewall... the pipe go through the left hand drive master cylinder holes....
talk to steve at brickworx.... He's done it a million times...
the number/email is on www.brickworx.com.au... (it's easier to remember)
PostPosted: Tue Nov 13, 2007 12:08 pm
[quote="cush"]i don't think you need to drill into the firewall... the pipe go through the left hand drive master cylinder holes....
[quote]
what if the car has heater hoses going through there already?
I don't want to call Brickworx - I want it published here so people can search and find out how it's done ;)
PostPosted: Tue Nov 13, 2007 12:12 pm
email him and tell him to reply here then .. :)
PostPosted: Tue Nov 13, 2007 12:16 pm
It all depends on the year of the air con system.
lots of different ways it goes through the firewall
Miniworx Centre 0883741299
Online BMW Mini Shop
Users browsing this forum: ken@miniauto and 160 guests
