It is currently Tue Jul 22, 2025 4:12 am
 Post subject: Twin SU's and prices
PostPosted: Mon Nov 12, 2007 8:11 pm
My uncle called me this arvo and said his friend has a set of genuine cooper S twin su's for $200 on a manifold. I'm going to check them out Tuesday arvo and was wondering if their was anything I should be looking for in particular. Also is $200 a good price for a pair on a manifold? I assume their 1 1/4 su's but I'll post more when I know more.
PostPosted: Mon Nov 12, 2007 8:21 pm
Give Ash some flowers Nick .
Check the numbers on them - that'll tell you what they are off of (there is a list on the MOCQ website. You'll be able to tell the size just by looking at them (they bolt onto the manifold vertically (ie the studs are above/below each other for 1 1/4's)
PostPosted: Mon Nov 12, 2007 9:12 pm
I think that's a fair price.
Factor in rekitting them (you have to buy 2 kits), give them a good clean, some air filters (if necessary), and you'll have some fun.
If I had a lazy $200 and a set of twins appeared, I'd probably buy them at that. :)
PostPosted: Mon Nov 12, 2007 10:12 pm
Had a look and could'nt find it :? , can you help with a direct link or cut&paste onto here :wink:
This space for rent
$200 is a good price, if you ask me. Just look at the prices right hand tanks are fetching.. twins in good condition on an original manifold would probably fetch a bit more than that on fleabay.
PostPosted: Tue Nov 13, 2007 8:53 am
Sorry, I was sure that's where I got it from. I'll see if I can find it.
<edit> It's a word doc, I'll email it to you.
PostPosted: Tue Nov 13, 2007 6:36 pm
twin 1 1/4's always go for around $300 on ebay, $200 is really good, even better if it has the original air filter box, if you dont get it, pass the details on to me.
im actually after some twin 1.5" su's
PostPosted: Tue Nov 13, 2007 9:25 pm
Kennomini, how did you go? Come back with a bargain?
PostPosted: Wed Nov 14, 2007 7:12 pm
I got them :) , they need a linkage and a few little bits but it all looks good.
I don't need them but thought I may in the future, so what's a good way to store them? Should I rebuild them so their ready to bolt on then wrap em in a rag and store them away or just oil them and store em?
PostPosted: Wed Nov 14, 2007 7:25 pm
This space for rent
Carbs usually store pretty well, the alloy doesn't corrode the same way that steel parts do. I'd strip and clean them, then put them back together without oiling them -- that's just going to attract dirt.
With steel parts, I've often stored them with a sachet or two of that silica gel stuff, it attracts and absorbs the moisture..
PostPosted: Thu Nov 15, 2007 7:39 pm
i sold a pair not long ago for 150 with two more old manifolds and other small bits n peices
Mearcat wrote:
