It is currently Thu Jul 24, 2025 11:26 am
 Post subject: Weber
PostPosted: Thu Nov 15, 2007 8:30 pm
Hey Guys.
Does anyone know where i could get a Weber second hand? Or are they hard to find?
And also is porting a head easy? and if so where could i get all the grinding stones and stuff from?
Thanks Blake
PostPosted: Thu Nov 15, 2007 10:01 pm
yeh potin a hed is easy fo shoooo
lol doin it properly is the hard part
Mearcat wrote:
PostPosted: Fri Nov 16, 2007 5:45 am
If you are going to have a go at grinding your ports dont go too crazy and grind too much out. Watch out for the push rod holes on the inlets and water jackets dont cut into them. David vizards book has got some good info on porting. After you have shaped and polished get the ports flow tested to make sure they are gana do the job :wink:
 Post subject: Re: Weber
PostPosted: Fri Nov 16, 2007 5:47 am
blake12345 wrote:
Hey Guys.
Thanks Blake
Look on eBay, and www.trademe.co.nz.
Also consider a Dellorto, which look and work the same- these were fitted to Alfas for many years and there are probably more about s/h.
For a road car it makes no difference.
Best advice re porting is go buy Vizard's book- `Tuning BL's A series engine', it worked for me.
Also read here- http://www.mlmotorsport.com/forum/index ... c,4.0.html
Happy grinding.... :lol:
PostPosted: Fri Nov 16, 2007 6:18 am
i do have a weber for sale pm me and talk turkey
PostPosted: Fri Nov 16, 2007 5:23 pm
blake12345 wrote:
Hey Guys.
Thanks Blake
Hi Blake...your engine is an 1100 and the head will need work...people usually recommend a 40mm Dellorto for such an engine.
Users browsing this forum: Bing [Bot] and 99 guests
