It is currently Wed Jul 30, 2025 9:03 pm
 Post subject: Re-sleaving
PostPosted: Sat Nov 17, 2007 1:29 pm
Can any brake place re sleave the Mini Brake and Clutch Master Cylinders or is it a more specialsit job that only some can do?
David L
PostPosted: Sat Nov 17, 2007 2:38 pm
Most brake shops don't even own a lathe.. so they send it out.
Hardly worth it when you can buy new for 120 bux. :lol:
Sleeving a tin tank one, the tank has to come off to drill the bypass hole.
 Post subject: Brake re-sleeve
PostPosted: Sat Nov 17, 2007 3:27 pm
Depends if you like what you have?
I had 2 'plastic bottle' type masters my Moke, had them both sleeved stainless steel and cost $160.00 for the pair complete job including new kit (except the lid seal :cry: ), but they are original and work fine, will never corrode, and shouldn't fail for years!
My Mini K has a new plastic bottle that looks crap, and seems to build up too much preload pressure, brakes often feel too tight, and you feel like the hand-brake may be on a bit...
But I agree, local brake shops just send them out, and then build them when they return from the machine shop, maybe you can find the machine shop, cause they are simple to build up, may save you paying some one else to do a simple job!
Cheerio,
Chris
Cool stuff!!
PostPosted: Sat Nov 17, 2007 6:46 pm
David,,, Brisbane Hydraulic sleaving service (BHSS)
PostPosted: Sun Nov 18, 2007 9:03 am
Thanks Matt
Another question - would you replate before or after sleaving?
David L
PostPosted: Sun Nov 18, 2007 9:08 am
get them to do that too, i`m pretty sure they do it before tho
