It is currently Wed Aug 06, 2025 5:09 pm
PostPosted: Sun Nov 18, 2007 11:59 am
Hey all
Got stuck into the track car today, I cut out the Weber box to replace it with a stock firewall out of my clubby, but before I weld the new one in, how different are they? I know the Morris ones have the large hole left of the master cylinder, but is that all? The clubby one im thinking of welding in has the hole in the centre.
Also, the floor is different to say the clubby one, is this simply because of the different gear boxes used?
in the Morris shell, (see pic) that hole is for the early type shift yes? but where the normal rod change hole should be, there is 4 threaded inserts.. any idea what these are? (sorry, no pic of that)
Thanks
PostPosted: Sun Nov 18, 2007 12:06 pm
Yes - Magic Wand shifter hole. Where are the threaded holes - in front of the cross member?
David L
PostPosted: Sun Nov 18, 2007 12:10 pm
yup, on each corner of where the rod change hole is on my clubby
PostPosted: Sun Nov 18, 2007 12:30 pm
Was the body originally a matic ? Sounds like the mounts for the auto shifter , I think the shift control cable went through the magic wand hole so it should have the magic wand hole and the threaded holes . Is the car type YMA2S4 (I think 4's the matic ???) ?
PostPosted: Sun Nov 18, 2007 1:58 pm
that's a serious weber box!
how come you don't want it there anymore?
PostPosted: Sun Nov 18, 2007 2:37 pm
Looks like a matic shell to me, they used the magic wand hole and shift boot for the shifter cable.
Only they had the 4 captive nuts in front of the crossmember.
PostPosted: Sun Nov 18, 2007 3:25 pm
Ah ok, sounds like its a mini matic to me, ill post some pics up tonight
Im sorry, it does not have any ID of any type.. I am yet to weld a steal front back on.
I cut the weber box out, because im putting it back to as stock as pos.
thanks
PostPosted: Sun Nov 18, 2007 7:13 pm
pic of the 4 nutsert things. just to make sure.
PostPosted: Sun Nov 18, 2007 7:36 pm
This space for rent
That's definitely the mount for the 'matic shifter.
PostPosted: Sun Nov 18, 2007 7:41 pm
sweet. any idea on year? I guess there is no way of finding out, without any body numbers. oh well, matic.. cool.
PostPosted: Sun Nov 18, 2007 7:46 pm
This space for rent
Best guess, sixty-something :lol:
No idea, without chassis numbers it's going to be pretty hard.
[edit] Unless of course you've got the original starter or wiper motor (or dizzy?), they have the month/year of manufacture stamped on them.
PostPosted: Sun Nov 18, 2007 8:03 pm
They only made autos between very late 67 and 70 so there is only about a 3 year window that is would have been made.
PostPosted: Sun Nov 18, 2007 8:10 pm
1.
which side do the wipers park? ie is it early wipers or late.
2. is there a number on the radiator shroud.....
PostPosted: Sun Nov 18, 2007 8:23 pm
Sorry doc, no wipers n no radiator shroud.....
does this help?
PostPosted: Sun Nov 18, 2007 8:25 pm
OK so it's 68 or later
how much later, who knows... :lol:
<edit> it's pre- December 1970 by the latches on B pillars.
Users browsing this forum: No registered users and 69 guests
