It is currently Wed Aug 06, 2025 5:09 pm
 Post subject: jacking it up
PostPosted: Wed Nov 21, 2007 4:42 pm
hi
where would be the best place to jack up my mini with a trolley jack and where to put stands
thanks
PostPosted: Wed Nov 21, 2007 4:43 pm
what do u wnat to jack up, front or rear?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Nov 21, 2007 4:47 pm
both i want to put it on stands
PostPosted: Wed Nov 21, 2007 4:51 pm
rear, on the flat sides of teh subframe, which run paralell with teh back wheels.
front, on amd-mk1 i have to jack on teh bits where teh front subframe join the cabin and the floor pan, if u understand, tehres a bolt that goes through teh floor, i use there as i cant get a jack anywhere else!
on my race car i just use the tierod mounts at teh front, wprkks for me.
jjust have a look, find some places taht are solid
tricky stuff :P
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Nov 21, 2007 5:49 pm
High heel ninja
Under the sump to jack up the front.
Doogie
PostPosted: Wed Nov 21, 2007 6:01 pm
Doogie
:shock:
PostPosted: Wed Nov 21, 2007 6:13 pm
High heel ninja
Doogie
:shock:
In the 16 years i've been fiddling around with mini's i've never had a drama with jacking a mini up under the sump.
Doogie
PostPosted: Wed Nov 21, 2007 6:15 pm
Your on something Doogie
I jack up with a Trolly jack on the cup where the Tie rod connects to the front Appron and put the Stands under the flattest section where the suspention sits inside.
For the rear, eather side and do the same for the stands.
After you are done ensure the car is steady on them.
Also while doing the jacking open both doors
PostPosted: Wed Nov 21, 2007 6:18 pm
pretty much exactly how i do it
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Nov 21, 2007 7:09 pm
Doogie
:shock:
Doogie
It is one thing to do it yourself, it is a totally different thing to recommend that someone else do it, especially if the person that you are recommending it to is a novice and has no idea of the condition of his engine mounts.
PostPosted: Wed Nov 21, 2007 7:24 pm
High heel ninja
As usual the Ausmini "nanny state" is at it again, the original post was asking where the best place is to jack up a mini. IMO that place is the sump, if other don't agree with that, fine then, put your opinion up, don't berate other cause their opinion is'nt the same as them. Everybody is turning into Jeremy Clarkson "if your opinion is different to mine then your wrong.
This site is full of young wanna be's who think they know all & full of over modding mods who jump at anything minor, we would'nt want to upset the BMW Bini owners now would we!!!!!
Im truly getting over this site big time.
Doogie
PostPosted: Wed Nov 21, 2007 7:31 pm
So, how many people have you pulled from under cars that have fallen on them? :roll:
PostPosted: Wed Nov 21, 2007 7:35 pm
somone has had abad day :roll:
chill out doogie, everyone accepts taht different people do things different way.
no need to ahve a go at everyone.
stop pointing the finger and look in the mirror
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Nov 21, 2007 7:36 pm
High heel ninja
How's that relevant? Who's under the car while its being jacked up?
PostPosted: Wed Nov 21, 2007 7:40 pm
Why is this?
Cheers Pete
Users browsing this forum: No registered users and 72 guests
