It is currently Mon Jul 21, 2025 5:43 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: What fuel to use?
PostPosted: Tue Jan 11, 2005 2:51 pm
Guys, after reading the today tonight story, I am wondering what IS the best fuel I can use for engine life and performance?
I just had the engine rebuilt but I didnt get the head converted to run ULP (although I did ask for that to be done, person rebuilding found out it would cost around $500 so abandoned the idea without even consulting me :( ) - and that was with the head already off :roll:
anyway, I have a rebuilt engine, no hardened seats, what do I fill it up with?
and what (if any) additives are a must?
Thanks
www.crazybitchracing.com
PostPosted: Tue Jan 11, 2005 4:02 pm
Premium unleaded with flashlube.
Flashlube is about $18 for a litre. Easy to use, just 1ml per litre of fuel.
I wouldn't even bother with converting a head, especially if there is nothing at all wrong with it.
Flashlube will also clean the inside of your engine, so should keep everything from your carbie jets to the spark plugs clean (unless, of course, the engine is in pretty bad shape).
We should be sponsored by flashlube here!!
PostPosted: Tue Jan 11, 2005 4:47 pm
Well said you may also use High Octane Fuel Like BP Ulitmate, Shell Optimax etc
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Tue Jan 11, 2005 4:57 pm
so I could safely put BP ultimate in it, and no need for additives?
That Flashlube sounds good though.. two options :) great
PostPosted: Tue Jan 11, 2005 5:16 pm
No U use flashlube as well as the higher octane petrol. I see u havent bought the mini eperience magazine which has an article in it explaining the different fuels and additives.
PostPosted: Tue Jan 11, 2005 5:36 pm
you could also use Nulon lead substitute, its the same thing as flash lube, but about a dollar cheaper, i have tried both and found no difference. i find using the higher octane fule gives me much better perfomance and fuel consuption.
PostPosted: Tue Jan 11, 2005 9:09 pm
All I know is that Nulon put that on the market to compete with flashlube. A flashlube imatation. Flashlube is tried and tested, eh doc? (no doubt he will read this post, hehe)
PostPosted: Tue Jan 11, 2005 9:51 pm
Could say a `flash' imitation...!
I like Flashlube, 'coz I know it works. :lol:
PostPosted: Wed Jan 12, 2005 2:15 am
need both of these:
1. good fuel (bp ultimate)
2. flashlube (even if you have unleaded seats, there are other parts in your engine that need the flashlube. it cleans the tops of pistons too, after pulling off the head this week you can see the metal on my piston heads under a thin layer of coke)
Inconspicuously Conspicuous
PostPosted: Wed Jan 12, 2005 7:37 am
You can get a unleaded conversion for about $200 at Mini Spares & repairs in Castle Hill.
I have have this done to my mini and put in PB Ultimate and my car loves the stuff.
Jet Red Mini K
PostPosted: Wed Jan 12, 2005 12:40 pm
My vote is also for Flashlube, the stuff runs great with BP Ultimate
Lillee - 1969 Morris Mini K
PostPosted: Wed Jan 12, 2005 1:41 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
flashlube has a thing that you can fit in your engine bay that meters the dose
makka
PostPosted: Wed Jan 12, 2005 2:51 pm
makka
Moreys and Lucas both do a Kit like that I think they call it a Power Booster Kit and is sucked through the Manifold By Vacum Only thing this does not do is clean the Jets in Carbys as it is not flowing throught the fuel line.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Wed Jan 12, 2005 3:13 pm
Hey Kev - is FlashLube the same stuff that was around when we were kids that was called "Upper Cylinder Lubricant"? Used to be available in the Oil Rack at the servo's in a container that was a steel cone with a thing like a glass hypo syringe mounted horizontal on the top with a long thin nozzle about 9 inches long. You drew up a "dose" in the glass barrel then squirted it in the tank before filling. Cost about 5 cents a squirt.
Disappeared off the driveways along with the glass refillable Oil bottles.
David L
PostPosted: Wed Jan 12, 2005 3:20 pm
1380 yellow devil wrote:
makka
The flashlube one (not sure if you're getting it mixed up on these other products) is in the fuel line, and is "driven" by vacume (manifold for eg.). So it does the same as it would if you squirt into the tank.
Personally i'm happy with squirting the stuff into the tank, doesn't bother me in the slightest (tho may bother the people waiting for the pump, hehe!).
Users browsing this forum: Bing [Bot] and 78 guests
