It is currently Fri Jul 18, 2025 3:55 pm
Post new topic Reply to topic  [ 305 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 21  Next
PostPosted: Sun Nov 25, 2007 7:50 pm
the gears should be case hardened I think, this is because you don't want the whole gear to be hard, only the outer wear surface. Correct me if I am wrong...
PostPosted: Sun Nov 25, 2007 8:41 pm
That is correct. They are case hardened. If hardened right through they would be too brittle. :wink:
PostPosted: Sun Nov 25, 2007 9:10 pm
here ya go..
i havent pulled apart my box to assess the damage as yet, but it will get straight cuts, upgraded helicals if i can find them or full replacement with an A+ and conversion from steel unijoints and remote change to potjoints and rod change.
PostPosted: Sun Nov 25, 2007 9:16 pm
So what is this myth about A+ gears being stronger.. they have more helix angle so teeth are thinner, and the ratios are all crap too (compared to an S or 1275GT...) :wink:
PostPosted: Sun Nov 25, 2007 9:31 pm
shrug, i've heard they are a lot better, and increased helix angle would mean they're quieter?
i dont think i have S ratios anyway, and i could use a longer diff, because i can reach max revs in top gear with the 3.44
PostPosted: Sun Nov 25, 2007 9:37 pm
Helix angle makes em quieter, that's about the only +.
Oh and yes the layshaft & its bearings are a better setup, they do last longer. :wink:
PostPosted: Sun Nov 25, 2007 9:44 pm
cheers, i will have to look into it further, straight cuts are a bit noisy for street use.
PostPosted: Sun Nov 25, 2007 11:38 pm
Spaceboy wrote:
here ya go..
diff pin looks harmless, i have some that are completely worn throu and snapped (killing the box). but not of torque, just factory 63HP injection engines with excessiv play between planet gear -> diff pin. may end like this
did you rebuild the box? or was it an old one with new engine on top?
maybe a stupid question, but i'm allways interested in such damages.
and a last one: you won't ship the pinion to me to make a small analysis of the material, will you?
Rover 214 atm ....
PostPosted: Mon Nov 26, 2007 1:04 am
KLAS wrote:
Dry Sump conversion....
DOZ
PostPosted: Mon Nov 26, 2007 8:14 am
My A+ Box did the same thing with the pinion gear with stockish 1100 power. Gearboxes aren't my thing, but is the pinion gear usually the first to go?
PostPosted: Mon Nov 26, 2007 12:36 pm
No the diff pin and planet gears are the first to go in a well built box. Unless you don't spin any wheels. As said before, it's all good unless you drive her like a goose.
PostPosted: Mon Nov 26, 2007 3:33 pm
ausmini mod
ausmini mod
Spaceboy, dont get me wrong... I DO believe your gears broke and things fail and break ...
I DONT believe its from torque and the power you have... I think its the way its driven.
How much power do you have exactly? (Flywheel, not rolling road)
I have had to rebuild my box, the baulk ring broke right through the hardened area! But that was simply a dud part (I didnt even get to drive the car yet - just fitted motor + box)
Straight cut would be better probably, so would LSD etc, but under 150hp we are not really getting into danger 'power' yet...
With 150hp, if you treat the box a little rough its worse than treating the box a little rough with 50hp...
Pete.
PostPosted: Mon Nov 26, 2007 5:36 pm
Just a clarification, it's torque that kills gearboxes, not hp. If you put a Celica 5 speed behind a 300hp diesel it would not last long.
FYI, I've got at least 150hp and the gearbox has been in 10 years now - its bloody noisy though (SC) :lol:
Daniel
PostPosted: Mon Nov 26, 2007 6:29 pm
Josh,
My post mortem of your box back then showed the pinion teeth had been cracked by a blow with a chisel or something, probably when someone was hitting the lockwasher.
I've seen it before... :wink:
PostPosted: Mon Nov 26, 2007 6:39 pm
The damage on Ryan's pinion looks identical..
