It is currently Sun Jul 27, 2025 2:10 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: mini rear cards
PostPosted: Sun Nov 25, 2007 9:22 pm
what should i make them out of, for my clubman
PostPosted: Sun Nov 25, 2007 9:38 pm
thin mdf
PostPosted: Sun Nov 25, 2007 9:40 pm
wheres cheapest?
PostPosted: Sun Nov 25, 2007 9:42 pm
mdf is really cheap, just go to your hardware store, bunnings or whatever.
its bendy too so you can flex it to get it in
Can't make them from bunnings. Too big and heavy, smells funny too.
I'm going to make some myself soon.
Plan is 3mm MDF, waterproofed, with some thin sponge under the vinyl or carpet that will be seen.
:D
PostPosted: Sun Nov 25, 2007 9:48 pm
yeah same here, thin layer of foam under the vinyl.
PostPosted: Sun Nov 25, 2007 9:53 pm
I made mine out of some Palight its foamed flat pvc sheets , so if it gets wet wont warp...your local platic shop will have it... :wink:
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Mon Nov 26, 2007 6:56 am
There are some bling stainless steel ones on fleabay at the moment.
They look great, but damn they would get hot in summer!!!
No more Minis!......For now.
PostPosted: Mon Nov 26, 2007 8:48 am
Can anyone supply a pattern for these??
PostPosted: Mon Nov 26, 2007 9:01 am
i used 3mm MDF (from bunnings) and some 5mm foam padding from clark rubber covered with normal vinyl on my first mini and didnt come up to bad, nice and easy to work wif and sat in the car nicely
Hi-Ho Silver LS1275
PostPosted: Mon Nov 26, 2007 9:17 am
I'd did the same with my first clubby...but I used Crushed Velvet :lol:
PostPosted: Mon Nov 26, 2007 9:20 am
lol pimp daddy
Hi-Ho Silver LS1275
PostPosted: Mon Nov 26, 2007 9:32 am
Gafmo/MiniMe,
Do you guys have a pattern/template one could borrow?
Unfortunately, mine did not come with the car.
Tricky
PostPosted: Mon Nov 26, 2007 9:34 am
sorry all i did was took out the old one and measured it off that, i have since thrown out the old one and sold that car, sorry mate
Hi-Ho Silver LS1275
PostPosted: Mon Nov 26, 2007 9:35 am
I used thin masonite type wood, I thought it might be more water proof with the shiny bit facing inwards! Doubt it. I also steer clear of foam padding personally, I don't like the look and find it can be a bit trickier to get a good result.
Next time I make some door cards I'm tempted to go get some of the corrugated plastic stuff they use for For Sale signs, cuts easy with a knife and won't be affected by water. Don't know how long it will last otherwise though. :wink:
