It is currently Sun Jul 27, 2025 9:52 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Nov 26, 2007 10:06 am
Yep it was nice and Brown which went well with the Orange Paint
Sorry Mine was over 20 od's years ago...I'm sure someone has a card laying around you can take the Templet off
PostPosted: Mon Nov 26, 2007 11:23 am
how did you guys make them stay in without falling out, did you do the bottom bit where you can put stuff and the side bits that fold too?
PostPosted: Mon Nov 26, 2007 4:34 pm
u cut them the correct size so once u put them in they bend wid the car and pop under the railing at the top, that hold them in
Hi-Ho Silver LS1275
PostPosted: Mon Nov 26, 2007 5:41 pm
Milatsmadmini
    Archangel007 wrote:
    Do you guys have a pattern/template one could borrow?
+1 :lol:
PostPosted: Mon Nov 26, 2007 7:05 pm
try the search
step by stepish on how to make your own trims
http://www.ausmini.com/forums/viewtopic ... door+cards
PostPosted: Mon Nov 26, 2007 8:17 pm
clubman ones are a bit different, well mine are anyway, mine dont cut off below the ashtray part. I think ill wedge a piece of wood down the bottom to hold it up better, because just sliding it in the slots wont hold it up properly i remember mine kept falling downl.
If anyone wants i can go measure mine and post templates on here
PostPosted: Mon Nov 26, 2007 8:37 pm
that doesnt sound right.
PostPosted: Mon Nov 26, 2007 9:01 pm
1970 mini K wrote:
try the search
You do actually say in that thread, and I quote "Use you old door trims as a template..........."
So, back to the original question, has anyone got a template I could borrow?
PostPosted: Mon Nov 26, 2007 9:12 pm
all i got to do is get some vinyl, will be similar to my seat , black with a white stripe :D
PostPosted: Tue Nov 27, 2007 10:31 am
ausmini mod
ausmini mod
Archangel007 wrote:
1970 mini K wrote:
try the search
I have mine out of the car, whats the best way to 'template' them?
I am happy to measure them but cant really trust how 'correct' that will be.
They are just to big to scan... hmmm
If you have anyideas Tricky, I am more than happy to do it.
I think I have the rear complete for clubbies (the rear trim, vinyl around door pocket, etc...
Ill try to make a template in the meantime, but let me know ideas for making templates guys.
Peter.
PostPosted: Tue Nov 27, 2007 11:08 am
Thanks Pristic!
Sticky tape a couple of sheets of A4 together, and just trace the outline.
Fold up and stick it in the post! :wink:
PostPosted: Tue Nov 27, 2007 11:47 am
Milatsmadmini
+1 for that idea :lol:
PostPosted: Tue Nov 27, 2007 11:55 am
This space for rent
Place the card on a flat surface, and take a photo from directly above its centre. Take measurements off the card, and draw those onto an A4 print of your photo. Then scan the result.
Not exactly a template, but probably good enough to make a replicant...
PostPosted: Tue Nov 27, 2007 12:31 pm
ausmini mod
ausmini mod
Here you go,
Measured.
Let me know if you want more or different.
Peter.
Image[/img]
PostPosted: Tue Nov 27, 2007 6:49 pm
Thanks Pristic!
thats the only way to go, or you could just go to your nearest mini shop or wreckers and get an old door trim...
