It is currently Sat Jul 26, 2025 12:46 am
PostPosted: Wed Nov 28, 2007 12:25 pm
I've seen various threads about standard and competition hydro bumpstops and read that the comp ones act as a sort of progressive cushion when the suspension is compressed past a certain point . What I'm wondering is would it be possible/beneficial to modify them to suit a dry suspended mini to stiffen the suspension further when it's being really pushed hard ?
PostPosted: Wed Nov 28, 2007 12:27 pm
A rear sway bar would give much better results?
PostPosted: Wed Nov 28, 2007 12:30 pm
Yeah , I've got one of them to go on one of the cars as well but they look poserish on a mini :lol:
PostPosted: Wed Nov 28, 2007 12:37 pm
benefits I don't know, but it wouldn't be super hard to put them on a dry car...
the fronts are easy, they install on the top suspension arm, either using a hydro top arm, or putting the bracket on a dry arm. Ditch the bump stop that is attached to the dry subframe obviously
the rears would be harder, as the bump stop mounts aren't there on the radius arms of a dry car, and the brake lines run across there (I think) I'd say you'd need to use hydro rear arms, and modify them to mount the damper - Dr Mini says you can cut off the hydro spring mount, and drill/tap the rear of the stub axle to take a bolt to go through the damper
PostPosted: Wed Nov 28, 2007 1:26 pm
I don't see why not?
Lillee - 1969 Morris Mini K
PostPosted: Wed Nov 28, 2007 2:09 pm
a sway bar actually wouldn't give the same type of results - maybe similar - but not the same. A sway bar won't prevent front to rear pitching, rear end squat under acceleration, front end squat under braking.... as both sides will compress together, not putting any torsion on the sway bar....
I use competition bump stops on my hydro car to cut down the pitching under acceleration
care to expand on your thoughts there Chong?
PostPosted: Wed Nov 28, 2007 2:55 pm
Not need on a dry mini.
Probably why the don't make comp bump stops for dry cars.
PostPosted: Wed Nov 28, 2007 3:39 pm
I can't see what they would do that your spring is not already doing? i.e. progressively stiffer spring rate.
PostPosted: Wed Nov 28, 2007 3:51 pm
can you buy competition rubber cones?
PostPosted: Wed Nov 28, 2007 3:52 pm
Was that a sarcastic question, Simon?
http://www.minisport.com.au/prod873.htm
PostPosted: Wed Nov 28, 2007 3:57 pm
My source could be wrong but I was told they were very similar to what we got orriginally here while the later developed rubber cones (mk iv onwards) got softer and softer .
PostPosted: Wed Nov 28, 2007 3:59 pm
If I were putting new ones in, i'd get those comp ones for the front and leave the standard 'Aussie' cones in the rear.
PostPosted: Wed Nov 28, 2007 5:22 pm
nope... but perhaps a 'prompting' one - consider yourself prompted
PostPosted: Wed Nov 28, 2007 8:24 pm
The instructions with the comp hydro rear bumpstops do give details how to fit them to dry cars. :wink:
I could say a rear sway bar is not needed on a dry car either, some of the fastest Nb racers run without. :lol:
PostPosted: Wed Nov 28, 2007 8:32 pm
really?? what do they say?
