It is currently Mon Aug 18, 2025 7:57 am
 Post subject: sills
PostPosted: Fri Nov 30, 2007 5:20 pm
has anyone had new sills put in there car
PostPosted: Fri Nov 30, 2007 5:23 pm
Yes. I am sure someone has.
PostPosted: Fri Nov 30, 2007 6:47 pm
no, did it myself.
not a difficult job, easier if the floor is straight, and the inner sills are not buggered.
easier to cut and gring the seam than to drill the spot welds - personal oppinion.
have fun...
 Post subject: Re: sills
PostPosted: Fri Nov 30, 2007 6:50 pm
the bean wrote:
why would u buy something with so much rust
PostPosted: Fri Nov 30, 2007 7:55 pm
This space for rent
:roll: :lol:
PostPosted: Fri Nov 30, 2007 8:41 pm
just make sure if you get someone else to do that they clean the inner sills well and give it a good dose of acid or similar. Ask them to etch prime/cold galve the inner portion too.
once its all repainted fill the sills up with wax/fish oil and drill some holes in it. Waters gunna get in there not matter what you do so just make sure it can get out.
If you do it yourself its not a really bad job. I was lucky I was able to break all the spots underneith with a chisel. then I did what jbeans did and grind the rest off.
I just measured them and went down to a sheetmetal place. they cost me about $20 each
blokeinamoke wrote:
PostPosted: Sat Dec 01, 2007 4:46 am
i think next time ill have them made, repo ones are a bit on the thin side.
PostPosted: Sat Dec 01, 2007 10:13 pm
I found it was best to grind them off, when i used the chisel it actually removed some of the inner sill too.
I made mine myself out of galvanised metal, was pretty easy but you need to remember to put a slight bow in them. I need to update my resto thread soon and it will have some pics etc of when i did it.
Users browsing this forum: No registered users and 290 guests
