It is currently Thu Aug 21, 2025 11:43 am
PostPosted: Fri Nov 30, 2007 5:48 pm
Everyone says you need new 'clock' springs when your door handles droop. Not if it's a MK1 (with English door locks?)
The slider and the cam are both worn which results in the handle spindle rotating too far and the handle itself goes beyond horizontal. :evil:
Well I've stuffed them now I may as well try a dob of weld and see if they can be rescued :?
David L
PostPosted: Fri Nov 30, 2007 7:40 pm
But the clock springs work so well and are so easy to install..... but, I'll admit, a bit pricey.
Cheers, Ian
PostPosted: Sat Dec 01, 2007 12:25 pm
Wombat, how hard is it to take that cover off the mechanism?
And how did you do it? Did it include an angle grinder..?
GP
http://www.reflectionsindigital.com/RID/Mini/Mini.html
PostPosted: Sat Dec 01, 2007 12:37 pm
Easy to get off - drill out the rivet flange at the back but there in lies the problem - it's not a rivet but a 'post' that is about 3/8" in diameter with a 5/32" hole through the middle - counter sunk with a lip at the top end and an narrow 'extension' at the other that passes though about 1/4" hole in the backing plate and is preened over to secure. By drilling off the preened bit the whole thing is ruined and new ones needed.
New locks are $45-$46 from Karcraft or $25-$35 from MiniSpares and others OS - I think I'll get new ones :?
David L
PostPosted: Sat Dec 01, 2007 6:53 pm
hmmmm, thanks. Might need to rethink what I'm trying...
Basically I want a passenger side door mechanism (with lock) on the drivers side, I was going to pull one apart like you've done, switch it over, then try and get it all back together.
GP
Users browsing this forum: Barkfast and 220 guests
