It is currently Sat Aug 16, 2025 11:03 am
 Post subject: Coolant
PostPosted: Sun Dec 02, 2007 1:46 pm
This may seem stipid to some but what should I fill my cooling system up with?
Straight coolant, straight water or a certain ratio of each?
PostPosted: Sun Dec 02, 2007 1:47 pm
Coolant will come either pre-mixed or not. Depends what ya buy to whether you mix it up.
PostPosted: Sun Dec 02, 2007 1:52 pm
It all depends on the coolant.
The cheap stuff you use straight (because you are paying for 2/3rd's water.
The good stuff you use a mix of about 2/3rd water to 1/3rd coolant depending on the brand of coolant. (it could be half and half, it could be 10 to 1, etc.)
You don't want to run straight water. It will turn brown and sludgy and soon block the radiator.
PostPosted: Sun Dec 02, 2007 3:02 pm
Resident Haemorrhoid
what about water from anywhere other than Goulburn :lol:
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Dec 02, 2007 3:56 pm
I always run distilled water and the castol corrsion inhibutor additive. I never run glycol type coolants as they are conductive.
PostPosted: Sun Dec 02, 2007 4:24 pm
I wondered about that - my engine has a harmonic balance and carries a good tune. (sic!)
PostPosted: Sun Dec 02, 2007 4:28 pm
maybe if you hum a few bars :P
 Post subject: BARS
PostPosted: Sun Dec 02, 2007 5:33 pm
Avoiding a few BARS leaks if you can...terrible stuff that gums up the works :roll:
PostPosted: Sun Dec 02, 2007 6:16 pm
So is water if you throw enough crusty block jibbers in it. Only a problem if you have stray currents from say a thermo fan however or you mix your inhibitors by brand.
http://www.are.com.au/feat/techtalk/straycurrent.htm
a good site all round actually...
PostPosted: Sun Dec 02, 2007 6:34 pm
The Forkmeister
Have to agree with the Bloke on this one, glycol actually makes water less efficient at transfering heat as well.
May the fork be with you.
PostPosted: Sun Dec 02, 2007 7:32 pm
I run Nulon glycol in the 1360, mixed 1:3 ratio with Sydney tap water, it cools fine, doesn't rust and lasts me for years. :lol:
If it ain't broke....... :wink:
PostPosted: Sun Dec 02, 2007 8:30 pm
I must be doing something wrong.... I just use straight tap water... doesn't go brown, and never gets hot
PostPosted: Sun Dec 02, 2007 8:34 pm
I can only highly recommend Red Line Waterwetter&Inhibitor-used with distilled water.
Users browsing this forum: No registered users and 129 guests
