3 months ago, I did a local motorkhana, and as you do, I put 50psi in my back tyres for it... I forgot, and continued driving around with 50psi until the next motorkhana, when I checked the pressures, 50psi was still there - "oops" I said, "wow, I didn't notice any handling difference at all" I said. I left the 50psi in them, and they're still at 50psi today. The back tyres are pretty much rooted, they're very close to the wear marks, and are badly scrubbed on the inside of the tread from when I had them on the front with the alignment out of whack (too much toe out)
the fronts tend to have about 28-30 in them, give or take... they're in OK condition, say 60%
all 4 tyres are Bridgestone SF226 - according to most people, an average "budget" 10x165 tyre
my mini has Hydrolastic suspension, pumped up to the factory specified pressure, 0.5 degrees of positive camber on the front wheels. About 3" between the tyre and the mudguard at the front, so factory ride height.
today it is PISSING rain in Albury/Wodonga, big storm, lightning, thunder, big puddles, rivers across the roads, you name it...
driving to where I'm working is about 15k's of average city roads, 50k's, a bit of 80, probably 8 roundabouts of different sizes, a few sets of lights. Some of the roads are in good condition, some are pretty miserable. They're all high traffic roads - at least, as high as you can get for an area with 120,000 people
It hasn't rained for a week or so, and has been very hot the last few days. The roads weren't especially greasy, but not "clean"
No matter how reckless I tried to be (when it was safe - no cars, nothing to crash into etc. etc.) I couldn't get the back-end to break away. I even did a handbrake turn on one bit of road and it took a lot of effort to get it to slide...
so why?
why didn't my car have obscene oversteer when I tried to flick it around a roundabout?
why didn't I do 360* spins when I went through puddles?
why did my mini behave the way it always does - straight and neutral?
_________________ did I tell you that I won a trophy?
