It is currently Sat Jul 19, 2025 3:15 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jan 12, 2005 8:31 pm
OR
Do a Kazjim Special and DROP the compression, mod the exhaust manifold, Drop a Turbo onto it, modify the carb for blow-through (or get a HIF-6 From a Metro Turbo)
:twisted: :twisted: :twisted:
Bobs your mother's brother.....
Total cost (if you do as much yourself as possible) is about $2000 ........
Total output.... about 3 times factory is a conservative guess at 10Psi boost ..... :shock:
kept up with Dean's 1380 (105HP on GR's Dyno....) on the main straight at Wakefield
Later
J
PostPosted: Wed Jan 12, 2005 8:39 pm
Yes but i don't think a worn down 850 could handle a Garret T3 strapped to the back of it, but then again it would be fun while it lasted and second hand 850's are cheap as.
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Wed Jan 12, 2005 8:44 pm
Easy.. use a small turbo from a Japanese Kei Class .....
Hey, yuo want to make power, you're rebuilding it anyway !
Its just the same as a standard rebuild, just lower compression and less advance !
I actually ran my current 998 in N/A trim for a year before dropping the huffer on.....
Doesnt look real standard, but crap, it beefs the midrange and top end incredibly !
J
PostPosted: Wed Jan 12, 2005 8:49 pm
We had a cappucino turbo there to try out.... but it looked so small, we needed two of them
PostPosted: Wed Jan 12, 2005 11:55 pm
i wasnt refferring to a STANDARD 850 doing 12000rpm.... and definately NOT a 850 crank :lol:
PostPosted: Thu Jan 13, 2005 12:47 am
mmm 850's are the squarest engines...
gotta love revs.
PostPosted: Thu Jan 13, 2005 5:47 am
gotta love revs.
Still undersquare bore/stroke, though- it ain't no Ford or Corolla! :lol:
850 crank's webs are thinner than all other Mini cranks, too (same width as 948 Minor).
I broke one thru the front web, and that motor never saw more than 6500 revs... :cry:
PostPosted: Thu Jan 13, 2005 8:19 am
I have never seen any mini crank over 10000rpm...
I would like think my race car could hit 10k but i'm to scared to try,
knowing the expense if it broke.
If your at 12000rpm you should have changed gear 6000rpm ago.
PostPosted: Thu Jan 13, 2005 10:34 am
OR you changed down WAY too early - picked 1st instead of 3rd? :lol:
PostPosted: Thu Jan 13, 2005 11:28 am
hahahha, ok so basically what kind of compression ratio am i looking at for a worked N/A 850 engine ? 10:4:1 ?
Hmmmmm..... Jennifer Garner
PostPosted: Thu Jan 13, 2005 2:12 pm
Roughly 10.5:1 depending on the fuel available in your area.
If you build it to run premium unleaded this will be fine.
Any more compression than this and you have to run 102 octane unleaded as we do.
But it's $3.30 a litre
PostPosted: Sat Jan 15, 2005 10:45 pm
ok then i just got a block, with a crank a cam and a head from miniimports. so its a starting point, i'll be on the look out to stroke it maybe :)
so can i use 944cc ? engine parts conrods... and whats the other piece i need for stroking :P
PostPosted: Sun Jan 16, 2005 6:02 am
No way you can stroke an 850 crank. If you wanna stroke an 850 get a 998 or 1098 crank, the block then needs the main bearing widths narrowed so the crank will drop in.
Then remember the 850's cam only has one bearing (front) not 3 like all others.
i think I would just get a 998/1098 block/crank/pistons, save all the aggro. :lol:
Plenty about... everywhere! 8)
PostPosted: Sun Jan 16, 2005 11:48 am
ok then, but what i really need now is people in melbourne/ vic who are willing t give me parts i will pay cash ! need conrods, pistons, valves valve springs will take small misc parts also complete engines or near complete ....
Will Pay CASH $$$$$
Users browsing this forum: No registered users and 112 guests
