It is currently Fri Jul 25, 2025 10:52 pm
PostPosted: Sat Dec 15, 2007 4:03 pm
Anyone in Brisbane got 3 meters of 2" steel pipe cause 1.5 meters of 1" pipe is not enough :evil:
David L
 Post subject: :idea:
PostPosted: Sat Dec 15, 2007 4:14 pm
are you tightening it or loosening it :?:
PostPosted: Sat Dec 15, 2007 4:17 pm
got a block and tackle. Run the block and tackle from the roof and take the free end and wrap it around the pipe and haul away - will increase the mechanical advantge without increasing the length of the pipe
PostPosted: Sat Dec 15, 2007 4:25 pm
No - I need a bigger pipe to fit over a bigger breaker bar - the smaller diameter one I'm using is bending without undoing the nut plus I'm starting to split the end of the pipe
David L
PostPosted: Sat Dec 15, 2007 4:35 pm
While you stand on the pipe get someone to hit the pipe near the socket with a hammer. :wink:
PostPosted: Sat Dec 15, 2007 7:46 pm
Thanks Morris1100 - that worked a treat - only took one blow with the hammer and it let go 8)
David L
PostPosted: Sat Dec 15, 2007 7:51 pm
Glad to help! It is a trick that should be spread around.
I invented that on the side of the road one night with truck wheel nuts and a short bar. The hard bit was hitting the bar while standing on it! :lol:
PostPosted: Mon Dec 17, 2007 10:29 am
If you have access to a decent rattle gun get that onto it. The impact does wonders with stuck nuts.
Pete
PostPosted: Mon Dec 17, 2007 11:01 am
Pete
Not to mention introducing stress faults into gear teeth that can cause fractures later down the track :?
David L
