It is currently Wed Jul 23, 2025 8:54 pm
PostPosted: Sun Dec 16, 2007 8:59 pm
I was under the mini today and noticed a sensor on the front right coming from the sump, its not connected to anything but it has the two connectors for something?
Any ideas? Electrical temp sensor? guessing....
meehal.
PostPosted: Sun Dec 16, 2007 9:01 pm
reversing lights
1964 998 Cooper , 1968 Morris 1100
PostPosted: Sun Dec 16, 2007 9:06 pm
What he said^^^ - power supply in - lead out to reversing light When reverse is selected the power is supplied to the globe which has the other side earthed.
+ _____________/ ________--globe--______ _ earth
David L
PostPosted: Sun Dec 16, 2007 9:14 pm
ha thats interesting. i the lights with reverse just brake and indicate.
thanks for that very helpful.
PostPosted: Mon Dec 17, 2007 7:53 am
You can wire up your indicators to act reversing lights. You need 3 diodes (4 if you want to use both indicators - separate supply to each side - don't loop a wire from one globe to the other or both sides will flash) (1N400*) will do - anything over 1N4001 is overkill but will do the job)
wire one into each supply lead to the globe + ---->|---- globe---earth
David L
PostPosted: Mon Dec 17, 2007 8:20 am
Later cars used dual filament globes in the indicators. On filament for flash the other for reveres. It gives you a slightly pale amber reverse light but better than nothing.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
