It is currently Sun Jul 27, 2025 10:33 pm
 Post subject: Clubby question
PostPosted: Tue Dec 18, 2007 9:25 pm
could someone tell me what this light on the tacho tells me and what the light on the right is for?
sorry about the poor photo!
Noli Illegitimi Carborundum
PostPosted: Tue Dec 18, 2007 9:39 pm
Red light is usually altenator not providing power isn't it?
Check alt belt and the alternator itself.
Although ususally the red light is on the speedo for this (?)
PostPosted: Tue Dec 18, 2007 9:49 pm
I have two lights on the tacho, the other one is directly opposite. I think the one shown is alternator as you say but the other one is a mystery and I'd like conformation anyway.
the instruments are the ones in my sunshine so should be standard clubbie 's'
PostPosted: Tue Dec 18, 2007 9:50 pm
there is the two red lights. THe one on the left is alternator, one on the right is oil pressure. I did read somewhere that the standard alternators don't neccessarily charge at idle, so that red light will come on. Mine stays on until she gets a rev. Then it goes out and stays out.
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Tue Dec 18, 2007 9:57 pm
oil pressure makes sense, thanks!
I was having a problem where the oil pressure light was staying on the the key out and the battery going flat, apparently not starting the car for 6 months is the cure as it seems to have fixed itself!
PostPosted: Tue Dec 18, 2007 9:59 pm
no probs! GOod old A series. More tempermental than a cranky old mother at times :D
PostPosted: Tue Dec 18, 2007 10:00 pm
it must have found out about it's upcoming new paint job and decided to play nice!
PostPosted: Tue Dec 18, 2007 10:15 pm
early clubbies had 'Alt' and 'Oil' marked on those lights. For some reason Leyland stopped marking the lights (cost?)
