It is currently Mon Aug 04, 2025 6:54 am
 Post subject: Do I have a problem?
PostPosted: Thu Dec 20, 2007 11:56 am
When I pulled the 3 synchro box apart the main gear cluster required deliberate dismanteling. When I pulled the 4 synchro cluster out it literaly fell to pieces ( I was lucky to catch the balls and springs)
Which is normal? Should I be looking for a problem?
David L
PostPosted: Thu Dec 20, 2007 12:44 pm
sounds like you have major 4speed problems David
PostPosted: Thu Dec 20, 2007 1:41 pm
In what way and what should I be looking for?
David L
PostPosted: Thu Dec 20, 2007 7:31 pm
Relax Dave, it's normal for the synchro hub balls to fly into orbit when removing the mainshaft. I think some books advise you to cover the top of the box with a cloth to avoid the necessity of scouring the whole garage floor for the missing balls & springs.
You've done good.
PostPosted: Thu Dec 20, 2007 8:32 pm
You can get the synchro hubs and sleeves out as an assembly without losing yer balls :shock: but it needs forethought...
remove the 2 detent plugs in the bottom of the box first, so the selectors & forks can slide with the mainshaft.
I hope you used the special service tool `XYZ' to remove the mainshaft bearing... Matt knows what this is. :lol:
Users browsing this forum: Bing [Bot] and 102 guests
