It is currently Mon Aug 11, 2025 10:49 pm
 Post subject: New floor pans
PostPosted: Sat Dec 22, 2007 8:58 am
do we have a "how to" on putting new floor pans in. as you can see from the pic it looks pretty yucky, but theres only a few holes and the left side has been done by a PO, but there is a little rust comming through. its not tragic I just dont know which way to go. Image
I live with fear everyday. but sometimes she lets me race.
PostPosted: Sat Dec 22, 2007 10:06 am
I'd be looking for some panels in better nick from a donor car as first move. Cut out the LHS bodge & the rusty RHS. That way you retain the original style pressings. Plan B would be to weld in some after market ones on both sides, at least it would look symetrical. No point welding panels on top etc, you need to get rid of the cancer & do a proper job.
If the car has hydro pipes, the after market ones are a pain as the channels are all wrong, but if you weild a MIG, they can be respectably modified with some effort.
PostPosted: Sat Dec 22, 2007 10:08 am
you can easily buy a replacement panel from the likes of karcraft/ minisport.
then sit teh panel in place and mark the edge.
then cut the hole out roughly an inch from the panel, then gradually trim to fit.
have fun.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Dec 22, 2007 10:21 am
The left side floor looks like it has been repaired with paper mache! Anyhow as mentioned the aftermarket floor pans do not match up with the Australian type but can still be used. You can either respectfully modify it like Pete says, or run your hydro lines underneath the floor rather than in the channel - early model hydro cars were set up like this from the factory.
By the way, I love you door check straps. 100% style.
PostPosted: Sat Dec 22, 2007 10:24 am
I knew someone with a keen eye for style would pickup on that :lol:
PostPosted: Sat Dec 22, 2007 10:48 am
Andy...looks OK apart from the trap door on the passengers side...
Look here...for same floor panel replacement
http://www.ausmini.com/forums/viewtopic ... ++canberra
PostPosted: Sat Dec 22, 2007 11:03 am
when we get together after xmas you can have a geek at it and see what you think?
PostPosted: Sat Dec 22, 2007 11:11 am
i have a brand new left side floor pan for sale
PostPosted: Sat Dec 22, 2007 11:16 am
yeah, I saw that in the 4 sale. where are you Bean, and how much
Users browsing this forum: No registered users and 222 guests
