It is currently Sat Jul 26, 2025 1:03 am
 Post subject: Rover - Aircon Question
PostPosted: Sun Dec 23, 2007 9:51 am
Should the box under the dash on the passenger side ice up if you do NOT have the air con running ?
I arrived in Batlow yesterday arvo after an 8 hour trip and found that it had iced up. It did it again this morning after a short trip.
I haven't had the aircon running at all yet, I just had the windows down.
No more Minis!......For now.
PostPosted: Sun Dec 23, 2007 9:58 am
Slow-Po
I've never had it happen it to me.
Good luck with the journey mate, glad to hear it's being good to you (was there every any doubt?! :) )
PostPosted: Sun Dec 23, 2007 9:59 am
Die Die Die!!
no it shouldnt... perhaps have a look or take it to an aircon place...
PostPosted: Sun Dec 23, 2007 10:41 am
Does the mini aircon compressor have a clutch pully? If so I'd say its stuck on, rather than turning on and off.
This means that the compressor is always turning, even though your aircon is switched off.
PostPosted: Sun Dec 23, 2007 1:38 pm
Solved it for the moment.
Have unplugged the compressor.
Gave me a noticeable power increase.
PostPosted: Sun Dec 23, 2007 1:45 pm
Die Die Die!!
yeah the aircon takes a fair bit out of your car... i drive a 998 so think about me haha
PostPosted: Sun Dec 23, 2007 2:27 pm
Also solved the reverse sensor not working.
The control unit has had some severe pressure applied to its casing (eg...being stepped on)..and the circuit board has microscopic cracks through 6 tracks around the resonator. Looks like when the case was squashed, the resonator took all the force and put it onto the board.
Dad is currently repairing it, pays to know an electronics engineer ;).
PostPosted: Sun Dec 23, 2007 2:42 pm
Reverse sensor now working. :)
PostPosted: Sun Dec 23, 2007 2:59 pm
Slow-Po
About 2-3 Hp. :wink:
PostPosted: Sun Dec 23, 2007 3:07 pm
It's on the hills around hill that it was noticeable. Can power up them in 4th without losing too much speed, whereas before it headed down to 90km/h pretty quickly.
PostPosted: Mon Dec 24, 2007 11:50 pm
ooh ooh... ask me.
i know how to fix it.
Miniworx Centre 0883741299
Online BMW Mini Shop
