I do them the way GR recommends, the rule of 9 (modified).
eg when #1 valve is wide open adjust #8, etc. This puts the one being adjusted right in the middle of the cam lobe's base circle.
`modified' means when #8 (exhaust) is open, you will find #6 (inlet) is near open too. Just rock the engine slightly until both are 95% open, then adjust both.
Repeat for the others. This way you only have to move the crank round 4 times, not 8.
You will find most good sports cams including RE13 are slightly noisier than stock cams, this is because initial valve acceleration is faster- which increases performance. You can't have everything-
BTW my RE282 cam runs .022/.024" (recommended) clearance with 1.5 forged rockers, and yes I can hear them- just.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
