It is currently Sun Jun 29, 2025 9:33 am
PostPosted: Thu Dec 27, 2007 11:19 am
as it was stuck to the magnet on my sump plug
PostPosted: Thu Dec 27, 2007 11:36 am
Do the ends look square and straight - or as if broken ?
Looks sorta like part of a spring washer ???
Also what sort of diff output shafts do you have ?
( If Hardy Spicer there are little "collet" things that go on the output shaft.... they have a similar shape and sit in a groove - kinda matches the marks in the first picture)
My 5c worth :wink:
PostPosted: Thu Dec 27, 2007 11:41 am
its a broken part of a whole part :lol:
both sides are worn, but it would have had a crossing at diagonals pattern on it.
PostPosted: Thu Dec 27, 2007 8:19 pm
It's a 5 cent piece....
(someone had to say it..)
GP
http://www.reflectionsindigital.com/RID/Mini/Mini.html
PostPosted: Thu Dec 27, 2007 8:24 pm
This should be in the mystery part games thread :)
I hope the rest of the part isn't trying to hold something expensive together...:shock:
PostPosted: Thu Dec 27, 2007 8:28 pm
Could it be a washer from under a valve spring? :?
Sometimes engine builders will fit a washer under the spring to increase seat tension. They are sometimes serrated like that.
PostPosted: Thu Dec 27, 2007 8:35 pm
how would it get onto my sump plug though :shock:
yeah i changed my mind about what blew in my gearbox because i didnt get any bits of teeth or gear come out, just this piece and some small fragments and shavings of metal.
PostPosted: Thu Dec 27, 2007 8:45 pm
Down the pushrod hole and then down the drain between the lifters? (I know it is unlikely but it is all I could think of!) :lol:
PostPosted: Thu Dec 27, 2007 10:14 pm
Is is serrated or is it just marked like that?
Pete
PostPosted: Fri Dec 28, 2007 7:15 am
it has a cross hatch pattern
PostPosted: Fri Dec 28, 2007 7:56 am
My bet is it's a spring washer. Only internal place these are found (I think) is on the rocker studs..... everything else had locktabs. Unless someone used spring washers instead.
PostPosted: Fri Dec 28, 2007 8:06 am
how does this explain my loss of 2nd gear :)
PostPosted: Fri Dec 28, 2007 8:08 am
OK then if it's a remote change or magic wand box yes there were shakeproof lock washers under the 1-2 and 3-4 selector screws. But not that type.. they are wrong. :lol:
Did you lose 1st gear as well? :P
PostPosted: Fri Dec 28, 2007 8:13 am
runs fine, 1st 3rd and 4th are as normal
boosts fine
2nd gear knocks and shakes but you can still get drive through it :shock:
the pictured piece was the only bit worth mentioning to come out of the oil
PostPosted: Fri Dec 28, 2007 8:20 am
You have partly stripped it- either 2nd gear, cluster or both. Usual story.... with too much torque. :lol:
