It is currently Thu Jul 03, 2025 5:26 am
PostPosted: Fri Dec 28, 2007 10:18 am
You have partly stripped it- either 2nd gear, cluster or both. Usual story.... with too much torque. :lol:
Ouch :shock:
Dicko
PostPosted: Fri Dec 28, 2007 11:07 am
except no teeth came out of the oil.
PostPosted: Fri Dec 28, 2007 11:46 am
It is probably only 1 or 2 teeth, gear teeth are pretty heavy, so they are probably still sitting in the middle of the box. Or they didn't totally break off...
Either way I'd be stripping it for a look, before a tooth jams the gears up. :lol:
 Post subject: Stuff on sump plug
PostPosted: Fri Dec 28, 2007 12:01 pm
iv been looking at crap on sump plugs for years and usually i can pick it, but this ones got me, i dont think its a valve spring washer or a selector retaining bolt washer, it could be a broken spring washer piece but it looks a bit to big so my guess is its a bit out of a idler or diff bearing. tell me more when you pull it apart. Thanks.
Have a Nice Day.
PostPosted: Fri Dec 28, 2007 12:35 pm
Could it be from the gear selector/bellcrank from the rodchange box? What do the spacers between the bellcrank levers look like? It would be about the right size and it could explain the loss of one gear.
Part 11 in this diagram...
PostPosted: Fri Dec 28, 2007 12:37 pm
its a remote change :)
PostPosted: Fri Dec 28, 2007 12:41 pm
Well that screwed that theory! :lol: :lol:
PostPosted: Fri Dec 28, 2007 7:50 pm
QUICK sell ya mini before more stuff goes wron....na sorry mate no idea........
PostPosted: Fri Dec 28, 2007 9:12 pm
Some aftermarket lockwashers look a bit like that, use two washers facing each other and they "ratchet" together when done up. If it has been apart in the past they might have used some? Any guess as to exactly where from would be just that but if you are missing a gear best to look for it sooner rather than later.
Michael N
PostPosted: Fri Dec 28, 2007 9:33 pm
I wonder if the other half of the washer is stuck in second gear? :shock:
PostPosted: Sat Dec 29, 2007 12:08 am
I wonder if the other half of the washer is stuck in second gear? Shocked
My thoughts exactly. If a bit of metal fell between the gears they could munch it down between the teeth. That sure would make it shake while retaining drive. You might be lucky and have minimal damage if you haven't driven it much like that.
Pete
PostPosted: Sat Dec 29, 2007 5:19 am
The gear rotation direction (think about it) means they would throw stuff up and out, not drag it in. My bet is still a partly stripped 2nd gear & cluster gear. Very common prob among you young blokes... :lol:
PostPosted: Sat Dec 29, 2007 5:26 am
Could be worse buddy... Could be me!!! :lol:
Daniel the concreter (for now)
1974 mini 1100, fully sick rims, disk brakes, new paint, air conditioning, cruise control,v-tech... wishful thinking
PostPosted: Sat Dec 29, 2007 7:00 am
well initially i was sure it had stripped teeth, because it felt the same as when the diff went but only in 2nd gear. but then no teeth came out and this washer did.
i know its possible the reason for the gear failure is the washer getting caught in the gear, but where is the washer from?
PostPosted: Sat Dec 29, 2007 7:33 am
There's always the possibility its a foreign object left in the casing from the last re-build. Or something used to bodge the last re-build, and now the chickens have come home to roost!
Start stripping and put us out of our misery :lol:
