d1ck0 wrote:
tinymorris1969 wrote:
ummmm why did u remove the emisson control/air pump from ur engine.... if ur mini came out with it u should have it on or ull be paying big $$$$$$ if u get pulled up for it
The Air Pump's were fitted as part of ADR 27 for emission requirements. That ADR doesn't exist any more, or at least is quoted as "not used" therefore would it be a problem to remove an air pump? It is not "superseded by" as some of the outdated ADR's have been. I was pretty sure ADR 27 was a time related thing, as no car of that age would comply after a few years anyway.
Not sure of what the legalities are with that one.
Dicko
Air pumps for these old things are NLA now anyway. They were fitted to dilute the exhaust with fresh air, thus lowering the emission figures when they were quoted in %.
Trouble was, they burned more fuel (and used power) to do it- if emissions had been quoted then in grams/mile I bet the numbers would have gone up, not down.
The whole emissions thing is a crock here- even modern cars are never tested annually (or even less frequently) to see if they still comply, unlike in the UK and US.
Don't lose any sleep over it...
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
