It is currently Fri Aug 01, 2025 9:50 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Just a barstard
PostPosted: Sat Dec 29, 2007 10:16 pm
I use to use an air one and then at home a lever. They are both very cumbersome, the air ones are good as you can a couple of bites at the job very quickly where the lever you have to compress the an compress and adjust then have another go.
I like the drill press idea sounds very civilised.
PostPosted: Sat Dec 29, 2007 10:52 pm
mickmini wrote:
if you have a drill press, just make something up to fit in that, and put a block under the valve when reassembling. You just use the downward motion of the drill head to compress the spring......I learned this from GR who happens to have a bank of drill presses, so dedicating one to be a valve compressor is not a problem for him :lol:
michael
ps no you don't turn the drill on :roll:
I have a hydralic press / Ram that I made for valve guides and the like I think I might knock something up to fit on there.
Although I do like the G clamp though
blokeinamoke wrote:
PostPosted: Sat Dec 29, 2007 10:56 pm
miniclubbhoy wrote:
How's about a pneumatic one:
http://www.youtube.com/watch?v=kbmoMiYIHdg
WOW
thats a mini head too?
Users browsing this forum: MiniPete, Steam, timmy201 and 90 guests
