It is currently Wed Aug 20, 2025 8:00 am
PostPosted: Thu Feb 14, 2008 5:36 pm
watto wrote:
Well, I'd like to know where that info comes from.
I've gone into a fair bit of detail in the next mag, but suffice to say, the Leyland comprehensive workshop manual states; "The identification plate was deleted from some Saloon Models in June 1969".
However, we were able to find a Mk1 Cooper S from April 1969 which had neither ID plate or compliance plate, and had no holes drilled in the bulkhead for the plate.
I would have thought the holes would be drilled when the plate was attached, but this is an interesting point. If the holes were drilled during the production of the shell, before painting, then it is possible they could fill with paint - but then they would have to find and re-drill the holes to fit the plate, which sounds like too much double handling.
Watto. :shock:
All the Australian Morris 1100 shells have all the UK ID plate holes even though they were not used and even though the panels were stamped in Australia. :shock:
Maybe the Minis were drilled when the shell was made. Maybe they stopped drilling them on a certain point but the shells were not used in consecutive order.
I found a Service Bulletin on the Sprite Club webpage.
SLS 169 2.5.1969
From Midget Car No. 1043, ID Plates Deleted. Car No. now stamped on body on LHS Dash Panel.
One would think that there must be a service bulletin for the Minis as well? From what I can see BMC documented everything. The problem was when David Abell ordered everything to be thrown out.
PostPosted: Thu Feb 14, 2008 5:50 pm
whats with all the Mr bean photos in mini adds? I get the reference but jeeez give it a rest.
blokeinamoke wrote:
PostPosted: Thu Feb 14, 2008 6:06 pm
He used to use photos of Minis hotlinked from Mini websites but the owners of the photos made him stop. :wink:
PostPosted: Fri Feb 15, 2008 7:58 am
Watto. :shock:
I figure the holes would have been done as part of a job lot, perhaps they were left over from earlier stocks only to be phased out as they ran out ?? Who knows. I'm not sure if the holes were drilled or pressed.
As for where it came from, my 2 mk 1.5 (apologies to Morris 1100 :) ) S shells I've have owned both had them.
Our Mk2 S (July '70) has ID plate holes - although one of them was hidden underneath the factory paint code stickers - that tends to suggest to me that they had been there from the production line.
In addition, all of the cars on my Mk2 S 'database' that I've been able to go over personally have had the ID plate holes. . .
PostPosted: Sun Feb 17, 2008 9:44 am
Might be one of those typical BMC/Leyland "now you see it, now you don't" situations.
Were Aussie 1100 body shells always pressed in UK? Mini shells were pressed in Aus from some time in 1964, and the 1100 was one of 3 model lines (Mini, 1100, 1800) listed for the Australian Government's Local Content Programme.
Watto.
Users browsing this forum: Bing [Bot] and 73 guests
