It is currently Tue Aug 19, 2025 8:05 pm
 Post subject: Cooper S Carpet
PostPosted: Sat Feb 16, 2008 8:36 am
Where can I get an original looking carpet set for a Mk11 Cooper S, with the proper insert for the drivers side floor mat, or alternatively does anyone make reproduction inserts for the carpet? Mk11, not Mk1.
PostPosted: Sat Feb 16, 2008 9:41 am
Minisport sell the inserts.
PostPosted: Sat Feb 16, 2008 10:17 am
Last time I checked, around Xmas, they only had the Mk1 ones.
PostPosted: Sat Feb 16, 2008 12:14 pm
Mk2 type:
It's not a substantial piece of rubber like the mk1, it is thin and simply stitched onto the carpet.
PostPosted: Sat Feb 16, 2008 12:29 pm
Is the rubber that goes into the floor carpet, the same as that showen in the photo?
PostPosted: Sat Feb 16, 2008 1:31 pm
Not 100 percent, there was a large discussion a while back about it and I'm sure I read it then but m brain has data dumped that bit...
PostPosted: Sat Feb 16, 2008 8:49 pm
Give Ash some flowers Nick .
You could just buy a normal carpet set and just get that bit stitched on. My local trimmer who I always go to had some original patterns that he stitched onto my carpet for me. Could be worth a try if you can't find exactly what you are after.
