It is currently Sun Aug 10, 2025 5:10 am
PostPosted: Wed Feb 20, 2008 11:32 am
If you are rebuilding a gear box that may be sitting a while before being put together with the block and actually run, would you use a heavier oil say gear oil at 90W to lube it all as you put it together ?
David L
PostPosted: Wed Feb 20, 2008 11:35 am
No just good ol' engine oil. what ever you use normally castrol, penrite fuch's :wink: etc, etc...
PostPosted: Wed Feb 20, 2008 12:02 pm
I actually use "STP" when building gearboxes,,,whether they`re going to sit for a while or not
PostPosted: Wed Feb 20, 2008 2:00 pm
n00b question: can the gearbox be rebuilt with the engine in the car? Either way is it costly?
Yesterday my 2nd gear lost a lot of its feel... theres not much of a thunk when it goes in, and it only goes in right at the end of the shifter travel.
PostPosted: Wed Feb 20, 2008 2:29 pm
Gearbox is an engine out job.
No two ways about it.
PostPosted: Wed Feb 20, 2008 3:44 pm
What one?
David L
Users browsing this forum: No registered users and 112 guests
