It is currently Mon Jun 23, 2025 10:49 pm
 Post subject: mystery head
PostPosted: Wed Feb 20, 2008 1:13 pm
hey peoples!
got given some parts on the weekend, in those was a head im just trying to find out wat type it is! on the top of the head it says 2af af2 as3 (all below each other) as well as mowog
Any ideas
Hi-Ho Silver LS1275
 Post subject: Re: mystery head
PostPosted: Wed Feb 20, 2008 4:15 pm
MiniMe87 wrote:
hey peoples!
Any ideas
Look for more numbers :idea:
PostPosted: Wed Feb 20, 2008 4:36 pm
Forum Graffiti
Normally they start with 12G--- or AEG--- etc.
Check out this handy little site 8)
http://drcwww.uvt.nl/~bogaard/heads.htm
Should help...
PostPosted: Thu Feb 21, 2008 2:46 pm
cant find any more numbers on it.....took some pictures will load them up tonight hopefully
Hi-Ho Silver LS1275
PostPosted: Thu Feb 21, 2008 3:45 pm
Have a look around the pushrod holes etc , I have a 12G202 head here with similar numbers beside thethermostat housing and the casting number is split into two rows beside a pushrod .
PostPosted: Thu Feb 21, 2008 6:26 pm
The numbers you want are always under the rocker cover- usually near the middle, but sometimes up between the 3rd and 4th rocker post pads on smallbore heads.
