O.k from memory you have to be careful ,,cut the hose of that fitting also,,and ''sweat'' eg ,,solder that fitting on to one of the reusable hydraulic fittings...you will see where to do this once you have the right fittings...So that what you are doing is putting the nut and its ''ferule'' onto a reusable hose fitting,,,BINGO
Also the brass nut that goes on the displacer after you've cut the thread is long,,,about 1inch to inch and a half long...it screws on the dick of the displacer,,and a fitting from the reusable...goes into that brass nut also,,,same way as the ''dick'' did..Don't forget to use the 577 loctite gas thread sealer...its yellow stuff and can hold pressures up to 2,000psi...GOOD STUFF...and will stop any leaks.....
The way i pump the system up is easy,,Get castrol antifreeze which is 97%glycol and mix it 50/50 with water....undo the front displacers in the engine bay..
Drill a hole in a metal tyre valve cap,,and solder it on to the end of a grease gun..
Pump fluid in until you see fluid at the front union,,where you undid the front displacer...this has just removed all the air from the rear displacer and the pipe,,up to the front union..
Next put your green fluid in a clean oil can...hold the front displacer hose vertical and fill the front displacer up..you have to ''tap'' it as your doing this,,it takes a little while but you will eventually fill that front displacer also....Put some of that sealer on the threads and quickly put the front hose on the union in the engine bay....repeat on the other side of the car
What you have done now is removed 99.8% percent of the air out of the system...
With the grease gun of the car pump it to fill the line of the grease gun''no air''..You have to turn the gun in circles to attach the tyre valve onto the car...Pump away until you get the right hight..
What i did next was pump it up and let it settle for a while...got a hose of a push bike pump..with the clip thingy on it,,and let it down,,,mainly to clean the whole system...Then pumped her up again... I must say you do not need to waste money on these tractor tyre valve's ...you do NOT need it at all....Cheers
