It is currently Wed Jul 23, 2025 11:28 pm
 Post subject: Gauges
PostPosted: Thu Feb 21, 2008 8:01 pm
hey
Just wondering if you can put different gauges to a custom setup for a Clubman. I had in mind oil pressure, temperature, rev counter/monster tacho.
Do they have to be specific brands or can you use anything?
Any help would be good
Thanks
PostPosted: Thu Feb 21, 2008 8:04 pm
I'm Bert , where's Ernie
yep you can.
someone will have more info, if your after speco gauges shoot me a pm.
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
 Post subject: Dash
PostPosted: Thu Feb 21, 2008 8:07 pm
you can put in anything you like, here is my dash i made up myself, the 3 centre gauges are oil,volts and temp all speco and the tacho is just a cheap brand, but i am going to change it to speco soon.
Steve
Classic Not Plastic
PostPosted: Thu Feb 21, 2008 8:17 pm
pls use the same brand for all the gauges or it will look sht :D
PostPosted: Thu Feb 21, 2008 8:20 pm
Give Ash some flowers Nick .
+1
PostPosted: Thu Feb 21, 2008 8:27 pm
High heel ninja
1018cc wrote:
+1
Smiths gauges are the ONLY gauges for mini's!!!!
Doogie
PostPosted: Thu Feb 21, 2008 8:29 pm
2 S's & a clubman wrote:
1018cc wrote:
+1
Doogie
Innos excepted. They got the good ones, Veglia Borletti. :wink:
Last edited by drmini in aust on Thu Feb 21, 2008 8:30 pm, edited 1 time in total.
1018cc wrote:
+1
Doogie
+1 :D (oh dear god....I'm turning into the bean! :lol: )
 Post subject: Re: Dash
PostPosted: Thu Feb 21, 2008 8:30 pm
Steve
that dash setup is very nice Steve.... but the tacho sitting up there like that looks HORRID!
PostPosted: Thu Feb 21, 2008 8:31 pm
When I want to be totally mislead, I always trust my smiths gauges to lead me up the garden path... :lol:
that's why most of them don't have very many numbered graduations on them..
PostPosted: Thu Feb 21, 2008 9:08 pm
would you need anything extra, sending unit, to install a tacho meter?
PostPosted: Thu Feb 21, 2008 9:10 pm
Tacho doesn't need a sender - it gets the signal straight from the coil :wink: All the tacho needs are wires hanging out the back (unless you get a mechanical tacho)
PostPosted: Thu Feb 21, 2008 9:30 pm
but you would need it for voltage or oil temperature...
PostPosted: Thu Feb 21, 2008 9:48 pm
steve 1965
when u want to change to speco, flick me a pm.
PostPosted: Thu Feb 21, 2008 10:21 pm
No sender required for volts. Sender units are required for electrical gauges (turn pressure etc. into an electrical signal). If you use mechanical gauges the oil pressure etc. is taken right into the gauge.
I had a specometer rpm gauge and found it highly inaccurate, the autometer that replaced it is spot on. Yes, smiths look the part in an original mini, it all depends what look you are after. :wink:
Carl
Users browsing this forum: Bing [Bot] and 95 guests
