It is currently Sat Jul 19, 2025 4:35 pm
 Post subject: Removing Door Hinges
PostPosted: Thu Feb 21, 2008 4:29 pm
hi has anyone ever removed the 4 door hinges, i want to remove them so i can chrome them but the bolts are too small and theres not enough room to remove them..
how can i unbolt them?
thanks
PostPosted: Thu Feb 21, 2008 4:42 pm
There's a fair chance that the nuts under the front wings will be covered in mud and crud and probably rusted so expect some bolts to break.
Your right, there is no room up under there so try a small ratchet and socket or ratchet spanners if you have some.
Renew the hinge pins and bushes while you've got them off if a bit worn.
Good luck.
Steiny
Image Image
PostPosted: Thu Feb 21, 2008 4:47 pm
ive tried with a ratchet but the actual piece that connects to the bolt is to thick to go around it... i got one of them out because the ratchet can fit around it and theres room for it to turn, but the further one and the top hinges i cant get to.
PostPosted: Thu Feb 21, 2008 5:00 pm
CRC, ratchet spanner or just a normal spanner and patiance. It's a bugger of a job. They're in a ning nong of a spot!
Image Image
PostPosted: Thu Feb 21, 2008 5:08 pm
CRC???
PostPosted: Thu Feb 21, 2008 5:35 pm
have someone hold the door and take turns trying to undo it, also swap arms and positions that helped us through it :o
PostPosted: Thu Feb 21, 2008 5:38 pm
Give Ash some flowers Nick .
lilmatti_69 wrote:
CRC???
equivelent to WD40, RP7, Innox etc. :wink:
PostPosted: Thu Feb 21, 2008 6:22 pm
I use a stubby ring/OE spanner with the ring end thinned down severely.
Sometimes a 1/4 or 3/8 drive socket and U/J works. It takes time- be patient, grasshopper.. :wink:
PostPosted: Thu Feb 21, 2008 10:05 pm
You've just given your age away ....
As for the hinges , jack the mini up , put it on good axel stands and take the wheel off . Clean as much crud away from the nuts and bolts as you can , the cleaner the better , then give them a good spray with crc/wd40/crickets piss/whatever and leave it to soak in for an hour or so . then respray them and try to loosen them , they might come off easy or they might snap/strip/frustrate the $@#$%@#%$ out of you but just stick with it .
PostPosted: Thu Feb 21, 2008 10:07 pm
tried today for around a hour but still not budging... goin 2 hardware 2moro 2 get more tools.
PostPosted: Thu Feb 21, 2008 10:10 pm
:D
How old do you think I am Sports?
Maybe it was an old can :D
Image Image
PostPosted: Thu Feb 21, 2008 10:11 pm
around 45 to 50 ???? Or did you find an old can in someone's garage ?
EDIT> Bugger , just checked your profile and looked at your myspace , 32 , so it was an old can :lol:
PostPosted: Thu Feb 21, 2008 10:20 pm
:D ah! :D
No cigar.
I'm 32.
I just always called cats piss CRC. Or cats piss!! :lol:
Image Image
PostPosted: Thu Feb 21, 2008 10:22 pm
So you hang around with old mechanics then or your dad plays with cars ? might be my memory but crc seemed to work better than some of the newer ones , especially on really rusted nuts like the door hinge ones .
PostPosted: Thu Feb 21, 2008 10:28 pm
My old man still has a can of CRC in the garage. you can just make out the writing and the red color. He just uses a little squirt each time, it still works. WD40 worked better when it first came out than it does now.
I live with fear everyday. but sometimes she lets me race.
Users browsing this forum: watsupskip and 87 guests
