It is currently Wed Jul 30, 2025 12:41 pm
PostPosted: Wed Feb 20, 2008 6:06 pm
For anyone interested I have found a supplier for "High Friction" shoes for drums...
Here
PostPosted: Fri Feb 22, 2008 8:57 am
Hi in my race car i run drums all around the backing plates has been flared out to scope more air in. i am just about to overhaul the front brakes by fitting new drums and slave cylinders and shoes. Ithe old shoes were called black flash linings i think. I am having trouble trying to get them if i do i will tell you where to get them from.
cheers jack
cheers jack
PostPosted: Fri Feb 22, 2008 9:05 am
As far as cooling, I have a set of front backing plates modified for use on a race car. The have holes drilled in the plate and little scoops welded on to direct air into the area behind the drum. No idea if it worked or not :lol:
Users browsing this forum: No registered users and 70 guests
