It is currently Sat Jun 28, 2025 2:33 am
PostPosted: Sun Feb 24, 2008 5:08 pm
Hi people,
Just starting to collect a few things(don't we all) for mini projects and wondered what sort of price a second hand set of 4 10" contessa's fitted with about 60% tread are worth?
Yes they are in good condition and standard alloy/grey centers and polished rims, complete with bolts and caps...
ta :)
PostPosted: Sun Feb 24, 2008 5:11 pm
200-400 depending on condition i reckon
PostPosted: Sun Feb 24, 2008 5:48 pm
I bought a set for $100
PostPosted: Sun Feb 24, 2008 7:14 pm
It depends on the offset as well. The ones that fit under the guards without flares are often sold at a premium because the Grp Nb racers use them. The ones that are offset outwards a bit more are usually cheaper.
Curly
PostPosted: Sun Feb 24, 2008 7:56 pm
which are which??
PostPosted: Sun Feb 24, 2008 7:59 pm
gareth-in-adelaide wrote:
which are which??
The ones the racers use are originally from a 998LS, so are called LS offset. The spokes are roughly level with the outer edge of the wheel.
The more common ones have the spokes about 25mm in from the edge, they are called Mini offset.
Were originally made for Minis with flat brake drums and no flares.
If you have S brakes or spacer drums you would need flares to make them legal.
PostPosted: Sun Feb 24, 2008 8:00 pm
Check out this thread http://www.ausmini.com/forums/viewtopic.php?t=33185
There are some piccies I put up that might help...
Ken
