It is currently Sat Jul 19, 2025 3:02 am
 Post subject: Morris 1100
PostPosted: Mon Jan 17, 2005 10:40 am
Theres a Morris 1100 at the U-Pullit at Elizabeth which is full of parts.
Disk & Drum brake parts, master cylinders,radiator expansion tanks etc.The car has disk brakes and I'm wondering if any of it can be used in a mini disk brake conversion ?
PostPosted: Mon Jan 17, 2005 12:30 pm
The stud pattern is different, so you can't use them. I'm sure others will add upon the differences.
PostPosted: Mon Jan 17, 2005 12:55 pm
I met a guy who has done it......no idea how though.....
PostPosted: Mon Jan 17, 2005 5:03 pm
It can be done using an adaptor plate on the Mini drum uprights, similar work to the Honda conversion. Disks and callipers will not fit under 10" wheels.
The master cylinder is a good one for a disk brake Mini. I think it is the same as a MkI Cooper S - tall tin type.
EDIT: Also the front CV's are the same as Mini disk brake ones.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Jan 17, 2005 5:15 pm
everyone is missing the obvious - go get that car right now cos I bet you $10 that it's got a 1275 in it - it's a morris 1100S - look at the motor, if you can put your finger on the head between the rocker cover and the thermostat housing then it's a 1275
the disks are no good, the uprights are too tall & you end up with no suspension travel
PostPosted: Mon Jan 17, 2005 5:48 pm
I don't think its a Morris 1100S.Engine number is 10YTaH 42713.
I guess I won't worry about the brakes but I did score what I think is a MiniK gearbox which looks in reasonable condition.It was on the back seat under everything else.
PostPosted: Mon Jan 17, 2005 6:13 pm
10Y= Morris 1100 (1098cc) engine. Nothing special.
Mini K and late Morris 1300 (and some 1100?) gearboxes with 4synchro had 22G1128 cast into them.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Jan 17, 2005 6:18 pm
Probably just a Morris 1100 remote one- they look similar to a K box outside. Check the casting number on front of box.. :wink:
PostPosted: Mon Jan 17, 2005 6:19 pm
22G1128
PostPosted: Mon Jan 17, 2005 6:28 pm
Get the bpx atleast...what was the Head number
PostPosted: Mon Jan 17, 2005 6:46 pm
oh poo, I was positive only the S's had disks, maybe it had an engine or brake swap in it's life.... never mind, the box is a good score
PostPosted: Mon Jan 17, 2005 6:54 pm
If its had an engine swap then its also had the plate swapped,still hanging on with one rivet.
I don't know about a brake swap but there was certainly enough old disks and calipers lying around it.
PostPosted: Mon Jan 17, 2005 7:28 pm
Drekkus wrote:
22G1128
Sweet!
PostPosted: Mon Jan 17, 2005 7:41 pm
All Morris 1100s had disks. They were the first car built in Aus to have them standard.
All Morris 1300s had auto gearboxes (some have been converted since)
There are a lot of bits and pieces that will fit a mini.
PostPosted: Mon Jan 17, 2005 8:00 pm
I thought there were some Morris 1300 (not 1100S) manuals?
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
Users browsing this forum: Bing [Bot] and 95 guests
