It is currently Thu Jul 31, 2025 8:27 am
PostPosted: Thu Mar 13, 2008 11:12 am
Wombat wrote:
For the non engineers here - what's a blue die spring and where do you get it and what do you ask for? :?
Die springs are used in metal forming dies, toolmakers use em.
Places like Automatic Springs in Sydney sell them.
I'll measure one up and post size later today. :wink:
PostPosted: Wed Mar 19, 2008 9:18 pm
Can anyone answer my other question? For this to work it has to supply +12v to the both rear indicators. I've only got the 1 spade to connect to the switch (pair of green wires, not sure on traces). So does this mean I'll have to route a +12v constant to the other side of the switch? (I'm fine with auto-electrics and wiring, just wanted to make sure this is how they work)
PostPosted: Wed Mar 19, 2008 10:58 pm
Positive feed to one side - other side goes down the back to the lights. When reverse is selected it closes the switch and provides power to the lights - other side of the bulbs go to earth. Source your positive lead from the switched side of the ignition switch
David L
PostPosted: Thu Mar 20, 2008 6:22 am
Cool, just as I suspected. Thankies!
