It is currently Fri Aug 08, 2025 4:21 am
PostPosted: Sat Mar 15, 2008 10:01 am
hey guys just did a bit of an overhaul on my 850,
1.5"carb
new radiator
generator conversion
it was over eating before which is why the rad went in. took it for a spin and i swear no less than 2 minutes later steam was coming out of it,
seemed to run ok, mixture isn't right yet and need to redo timing anyone ot any ideas on what the cause would be
1962 850,Frog
PostPosted: Sat Mar 15, 2008 10:12 am
You converted to a generator? :D
Have you got a temperature gauge connected? If not connect one, as you can get what looks like steam from the coolant even though it is not boiling.
2 minutes is very quick for it to overheat from cold - unless you mean 2 minutes of driving after having warmed it up. I would look for any blockages or perhaps a dud thermostat (is the top radiator hose hot, and have coolant in it?)
I would also recommend you check the timing and tune the carburettor properly - a mixture of incorrect ignition timing and lean carburettor can make the engine run artificially hot and cause all sorts of problems.
PostPosted: Sat Mar 15, 2008 11:07 am
you could have a airlock in the head...Run the engine and pump the top heater hose from the thermostat once it has opened. Did you also change the thermostate as it could be stuck
PostPosted: Sat Mar 15, 2008 11:39 am
It must be overweight and the engine has to drag too much weight around :D :D :D
PostPosted: Sat Mar 15, 2008 4:41 pm
overheating that quick is most likely a timing problem, second to that is a stuck thermostat, and no impellor on the water pump
PostPosted: Sat Mar 15, 2008 5:36 pm
I`ve had a mini recently that had a blocked bottom rad hose & blocked water pump,,, old gungey corrosion inhibitor all caked up & solid.
My bet with this one is on the thermostat being stuffed tho
