It is currently Wed Jul 30, 2025 1:28 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Mar 18, 2008 3:10 pm
It may be firing correctly on the flywheel timing, but it may be firing on the exhaust stroke instead of the compression stroke. Easy mistake. Will cough and spit through the carby as it tries to fire if this is the case.
1962 Mini Speed sports sedan
PostPosted: Tue Mar 18, 2008 4:48 pm
No coughing, no spitting, no attempts to fire at all.
I know the ignition timing is correct, it is firing number one spark plug when number one piston is on compression, at a few degrees (3 ish) BTDC.
Hey, that confirms the cam timing too! Hmm,
Keep your ideas coming!! Anyone else want to throw in an opinion for a spark plug Gap for NGK BP6ES on a Vhigh compression A series on points, running AvGas?
Matt
PostPosted: Tue Mar 18, 2008 4:57 pm
you sure you have compression with this, have you taken the rocker cover off to make sure you have the valve timing right,
i drove my car around heaps, for nearly a year and then left it for 2 months and wouldn't start, it twas the leads,
PostPosted: Tue Mar 18, 2008 5:17 pm
Yep, well actually, it is the old thumb over the spark plug hole trick. Hard to miss that. (but yes, valve / cam timing is correct.)
I also get spark from each of the spark plugs, so leads aren't an obvious candidate. Might take a known set up to check them against. Good to rule these things out.
Hmmm, how can I check the accelerator pump action of the weber? Without removing it?
Thanks Guys!
Matt
PostPosted: Tue Mar 18, 2008 6:29 pm
Thanks Guys!
Matt
pull the 2 pump jets out, look in de holes... :wink:
PostPosted: Tue Mar 18, 2008 6:40 pm
Stinking Animals :x You know what they say Matt "They're only as good as their trainers" :P :lol:
If i actually had any ideas i'd contribute something usefull. Tha answer is probably in that book you lent me :lol:
Im hilarious when i dont know stuff :lol: :lol: :roll: :roll:
PostPosted: Tue Mar 18, 2008 7:11 pm
I put a brand new Holley on my Holden and had to the fill the bowls with petrol the first time before it ran. I couldn't work it out for ages. It just must have been the accelerator pump cavitating or something. I don't know if a weber is the same but try filling the float bowls with petrol.
PostPosted: Wed Mar 19, 2008 7:40 am
one other thing have you tried any canned good, ie aerostart, start you bastard, even thinners
PostPosted: Wed Mar 19, 2008 8:57 am
Thanks Guys, it is good to have some more ideas. (Yep Anthony, even yours :wink: :lol: Bro Town rules eh bro)
The float bowl is filling, checked that one, I can also see the fuel getting into the cylinders.
Haven't tried any of the Aerostart type products yet. Will avoid that if I can.
Hmmm, it's when I need to do things like pulling out pump jets (thanks Doc) i wish I had me a Weber Manual. Anyone recommend a good one?
Next step is to adjust the spark plug gap down a bit, (0.032" to 0.025") try again (with a smidge of choke) and if that doesn't work, bleed the brakes then roll down a big hill, and roll start it! (so the starter isn't taking valuable power from the ignition system.)
Matt
PostPosted: Wed Mar 19, 2008 9:39 am
Matt
Pump jets are under 2 brass plugs on top ie. in line with the carby barrels, near the idle mixture adjuster screws.
Try putting your hand over the air inlets whilst cranking, that'll choke it. :wink:
PostPosted: Wed Mar 19, 2008 10:17 am
2 much air? How is your manifold gasket, flexible weber seal or have you forgotten to block the vacuum hole in the manifold.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Wed Mar 19, 2008 10:21 am
yeah, it sounds like he`s just not used to a weber & it being a fresh engine he`s probably babying it
give it a few more pumps & then pump it while you`re cranking
get a second battery hooked up just for the starter if your litte race battery is down in grunt, so you`re not stealking power from the coil while cranking
it`ll fire up, just have faith & hold your tongue to the left side , lower section of your mouth & away she will go
PostPosted: Wed Mar 19, 2008 10:35 am
are the plugs wet after cranking?
If not, why not?
PostPosted: Wed Mar 19, 2008 11:46 am
weber was rebuilt by Ken so I reckon she'll be spot on.
PostPosted: Wed Mar 19, 2008 11:50 am
Check your compression with a guage, 50psi could feel like 150psi but the motor probably won't go,
also check vacuum lines, are you running a power booster for the brakes, check that yo're not loosing vacuum through that,
have you got the rubber o rings between the carby and the manifold and are they in good condition, has the carby been jetted for a mini?
My checklist would be Compression, Timing, Vacuum leaks,
then start getting desperate and tow start it
Users browsing this forum: Bing [Bot], winabbey and 92 guests
