It is currently Mon Aug 18, 2025 12:36 am
 Post subject: Josh's Mini Dumped!
PostPosted: Fri Mar 21, 2008 7:00 pm
I found josh's mini today dumped! just sitting out in the middle of the road :shock:
He had also dumped his sister along with it and from what i could gather he had done a runner!
It'll learn you to cut corners now won't it mr josh! :wink:
PostPosted: Fri Mar 21, 2008 7:25 pm
More details Aaron, was he being a silly bugger.
PostPosted: Fri Mar 21, 2008 7:53 pm
Motor was spiny spiny but there was no goey goey.....I am sure there will be more info from the source :oops:
PostPosted: Fri Mar 21, 2008 9:51 pm
bummer! poor fella
PostPosted: Sat Mar 22, 2008 12:42 am
:lol:
Yea i busted one of the driveshafts in half today :( just sheared it completely trying to test their strength :roll:
Took my sister for a drive and she was complaining about the clutch being so hard and i told it was so you could do this and i went to take off with a few revs and it didn't proceed to go anywhere. I knew instantly what had happened.
This guy we passed earlier picked me up and took me home so i could get a car and tow it back. When i got back my sister said someone had stopped by (Aaron) and asked if "that was Josh's mini?" and that he was going to talk to "googie" :lol: She was a bit shocked that someone found it so quick and knew the car haha it's good to know there are people on here looking out for everyone :)
Time to get some billet shafts!
PostPosted: Sat Mar 22, 2008 10:48 am
We're they starlet shafts welded to mini shafts? Your thread is too big to look through.
Reason I ask is in the not too near future I'll need shafts and I've heard about a 50/50 argument for welding shafts (cheaper) vs. billet custom shafts (stronger).
I'm leaning towards the more expensive billet shafts.
Oh PS. If you had a dodgy old, salisbury type LSD it would strill have driven home i believe, or so I've read.
PostPosted: Sat Mar 22, 2008 11:51 am
No they were cut down, resplined and hardened like 99% of the other conversions.
I'm either:
a) too harsh with the stronger mounts, clutch, lsd and tires.
b) had something go wrong when they got made (dan is running shafts from the same place though with no problems so far)
Yes i'm well aware if i had a traditional lsd it would have driven home. I still would not have bought one though.
PostPosted: Sat Mar 22, 2008 3:00 pm
Ok fair enough. Well the go here in SA seems to be custom made shafts. So i'll just go with the flow.
PostPosted: Sat Mar 22, 2008 3:03 pm
Post a photo of the busted bits just to give us amateur metallurgists something to appraise. :D
PostPosted: Sat Mar 22, 2008 3:18 pm
Were they crack tested ?
PostPosted: Sat Mar 22, 2008 3:33 pm
PostPosted: Sat Mar 22, 2008 3:39 pm
I wonder if it started from this? :?
PostPosted: Sun Mar 23, 2008 5:49 pm
After printing the 2nd pic so I could see it (my monitor is nearly dead) I reckon the crack started from the circlip groove.
This is the 99/100 spot where even low powered Minis can break a shaft.
For ST competion shafts in UK (p/no C-BTA1267, a pair) they deleted that groove and welded a stop collar on instead.
PostPosted: Fri Mar 28, 2008 11:02 am
shafter breaker :lol:
even I'm not that rough!
PostPosted: Fri Mar 28, 2008 11:28 am
no just gear sticks :lol:
Users browsing this forum: No registered users and 144 guests
