It is currently Sat Jul 19, 2025 3:22 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jan 17, 2005 11:22 am
Just be careful with mandrel bent extractors.
The centre pipe doesn't allow you to use single or twin carb manifold. Weber only.
Whatever you run, just check your inlet manifold before fitting
Thank god, got me worried there.....thats what ihaeared and
jumped to conclusion. :D
PostPosted: Mon Jan 17, 2005 12:06 pm
Mandral Bending is just the way they bend the pipes...and is better.
It does not give a kink...(Kind Of) in the pipe
PostPosted: Mon Jan 17, 2005 12:12 pm
Maniflow LCBs are not mandrel bent, but the centre pipe comes out of the head a bit straighter than the Oz made ones do. :wink:
PostPosted: Mon Jan 17, 2005 2:48 pm
Talking about intake manifolds and G rusell by the way, I was there last week and he seems to have produced one of his famous manifolds (with the little step at the lower edge) that fits without mods to the firewall.
PostPosted: Mon Jan 17, 2005 4:08 pm
Yeah I've got one here- bare carb might fit, but not with any filtration.. :cry:
If it did, it would be on my car by now!
PostPosted: Mon Jan 17, 2005 6:31 pm
So wat do the extractors cost from heritige MG?
PostPosted: Tue Jan 18, 2005 2:16 am
about $230.
Kev he was standing there telling me that it is very much possible, I'll have to check it further.
BTW he expressed his views on unleaded and flashlube - he doesnt run any additives and doesnt use hardened seats. What do you reckon?
PostPosted: Tue Jan 18, 2005 6:02 am
He doesn't do any miles.. drives the BM instead. :wink:
If you want to see what that can do to a head in 6 months I'll put some pics up here tonite. :cry:
Yeah he told me this manifold fits too, but unless you want socks poking inside the car, nothing in the way of a filter will go on!
Put it this way- it's about 1-1/2" LONGER than your Redline one.. :wink:
PostPosted: Wed Jan 19, 2005 4:18 am
Ok well I'll tell him you called him a liar :) - seriously though thats why I was aprehensive and didnt buy the manifold straight away - remembered what you said earlier. Too bad though I reckon he doesnt have to exagerate the performance gains with that manifold- maybe we can all coerse him into making a slightly shorter one with that famous step in it.
PostPosted: Wed Jan 19, 2005 5:50 am
I'm going to move the speedo binnacle into the car about 1" or so, use early Clubbie speedo cable, then do a shallow box for a Ramflo filter. :wink:
Making the manifold shorter will put corners in it and bugger the gas flow...
Worth fitting as is. When mine is in I'll post pics.
:idea: Might fit it for Wakefield Pk without filters, just to see what `performance gains' it has.. :P
PostPosted: Wed Jan 19, 2005 8:19 am
I've got a right angle angle joiner on my speedo end,
makes it a lot easier on the speedo cable
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Wed Jan 19, 2005 11:26 am
Brickworx, where did you get that ?
With the Turbo Plenum taking most of my Speedo "hole" if i dont get the cable aligned "just-right" it goes snap within 20 klm. . . like it is at the moment.....
I was going to do the DRMINI SPeedo move, but if its just an adaptor, then I'm willing to give it a go!
J
PostPosted: Wed Jan 19, 2005 3:52 pm
I was told they are an old jaguar part that you should be able to pick up from a Jag wrecker - i was thinking of getting one myself...
Geoff
PostPosted: Wed Jan 19, 2005 5:14 pm
Our other car (Barney the pretend S) has an early Clubbie cable, the binnacle is screwed through the parcel tray trim from inside the car. Wires are long enough that I can tip it onto the pacel tray. :wink:
I'll make mine the same, put 1" spacer under the trim... bugger originality! :lol:
