It is currently Fri Aug 08, 2025 5:46 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Mar 24, 2008 6:18 pm
If there are more holes or dodgy spots lower down on the sills I'd be putting new ones on.
Make sure you fix the rust BEHIND the sill when you get it off... I'd then paint the whole insides with coldgal paint before welding the new sill on.
PostPosted: Mon Mar 24, 2008 6:19 pm
I had a floor made of Castrol R cans once :oops:
PostPosted: Mon Mar 24, 2008 6:20 pm
go to a store and get some cold rolled or galve ya titeasses :D
You can get something a little thicker than normal body panels. That way you can concentrate your heat on the new metal and refrain from blow Mucho holes.
blokeinamoke wrote:
PostPosted: Mon Mar 24, 2008 6:22 pm
Galvo sheet has too much zinc on it, I find zincseal welds much better.
I use 1.5mm zincseal for floor patches. I bought a whole bloody 8' x 4' sheet to do the Moke... :oops: :lol:
PostPosted: Mon Mar 24, 2008 6:28 pm
I bought two - didnt have much to spare either :shock:
for patches - with the assumption that it will be worse than it looks and therefore will be redone soon enough and a larger scale - I use any aged steel I can find of a similar guage.
If I have found the extent of the problem - either a new panel or a third I use new sheet.
PostPosted: Mon Mar 24, 2008 7:22 pm
Old computer cases have great steal in em. Some of the older server cases have awesome paint finishes (powder coat in some cases), which won't rust for some time (if at all).
PostPosted: Mon Mar 24, 2008 9:01 pm
Milatsmadmini
all of this is taken in..... thanks a lot everyone! so in the morning ill be looking around for either old car doors/panels, old washing machines and computer cases??? lol
either way ill find something to do it all up.....
doc.. wats a coldgal?
is that close???
PostPosted: Mon Mar 24, 2008 9:11 pm
No but its warming anyway
PostPosted: Mon Mar 24, 2008 9:17 pm
Mustn't be that bad, there's no hard nipples :shock:
PostPosted: Mon Mar 24, 2008 9:23 pm
is that close???
Nope, they're Hot :shock:
PostPosted: Mon Mar 24, 2008 9:50 pm
is that close???
Nope, yours is better looking. :P
Coldgal is zinc paint, White Knight I think- it's about 90% zinc and called that because it's like cold galvanising. Galmet does one too, there are other brands.
Good stuff, I welded my galvanised boat trailer 10 years ago and there's no rust yet where I put coldgal on it. Salt water use and all. 8)
PostPosted: Mon Mar 24, 2008 10:00 pm
Milatsmadmini
could i use it to paint the bottom/underside of the mini too or do you use somthing else?
PostPosted: Tue Mar 25, 2008 6:39 am
I guess you could do underneath but you can't put other paints over it.
Most people use POR15 or `stonechip' type underbody paint.
PostPosted: Tue Mar 25, 2008 7:57 pm
Milatsmadmini
where abouts do you find these types of paints? is there a cheaper aussie made version thats easy to buy?
PostPosted: Tue Mar 25, 2008 8:03 pm
ausmini mod
ausmini mod
I dont believe you, I am still looking... and wont stop till I find at least one. :)
Users browsing this forum: Bing [Bot] and 96 guests
