It is currently Wed Jul 23, 2025 12:38 pm
PostPosted: Thu Mar 27, 2008 6:14 pm
aaron wrote:
its the circlip for the drop gear bearing. there are two, one on each side of the bearing to hold it into place. I just replaced this bearing and it looks to fit the bill. :cry: It may or may not become and issue....
Late rodchange boxes had none at the back (ie inside the box), they have a shoulder there instead.
I have often left the front one out over the years (when they got lost), never seen a bearing move yet.
It takes serious puller power to wind these puppies out when replacing them.
 Post subject: Hmmmmm
PostPosted: Thu Mar 27, 2008 7:38 pm
especially if the reason the circlip "popped" out was due to the bearing collapsing :roll:
 Post subject: Re: Hmmmmm
PostPosted: Thu Mar 27, 2008 7:44 pm
aaron wrote:
]its the circlip for the drop gear bearing. there are two, one on each side of the bearing to hold it into place. I just replaced this bearing and it looks to fit the bill. :cry: It may or may not become and issue....
Well if it is, the idler bearing itself can kiss it's arse goodbye................. :cry:
PostPosted: Fri Mar 28, 2008 3:11 pm
Hi Rod. In the 'photo with the ruler....I reckon from the radiii of the broken clip there's still a bit missing. Did you get it all out. :?:
PostPosted: Fri Mar 28, 2008 3:45 pm
That's all that was stuck to the sump plug.....
Rod Image
