It is currently Sun Aug 17, 2025 6:00 am
 Post subject: K&N Air Filter
PostPosted: Thu Apr 03, 2008 8:17 pm
Hi
I have a set of twin 1.5 Su carbs and need some air filters,
Looking at K&N which are realtivley cheap and easy to post.
The question is will they fit.
I have located a set part number http://www.knfilters.com/search/product ... od=56-9320 they have an offset hole
The manifold is a standard twin SU 1.25 alu modified to fit 1.5's
Regards
Kiwiinwgtn
PostPosted: Thu Apr 03, 2008 8:45 pm
Manifold is a standard twin SU 1.25 alu modified to fit 1.5's
Yes - I have the same setup ready for the "historic rally mini" project... and a pair of 56-9320 - should fit with no problems.
PostPosted: Thu Apr 03, 2008 9:09 pm
And if you want stubstacks to go in there I make them to suit 1-1/4" and 1-1/2" SU, straight or offset as shown.
Straight ones are $50/pr, the offset ones $60/pr (more work).
Prices include post.
PostPosted: Thu Apr 03, 2008 9:16 pm
I've been looking for these filters for ages :roll: now I have a part number we'll see if they can find one for me.
What's the benefit of the substack? and dose it go between the filter and the carb?
PostPosted: Thu Apr 03, 2008 9:26 pm
The stubstack goes inside the filter against the backplate, basically it puts a radius on the mouth of the carb. You can see up to 5% improved airflow according to Vizard.
These also fit Ramflo filters.
PostPosted: Fri Apr 04, 2008 6:29 am
They look nice doc
PostPosted: Fri Apr 04, 2008 8:10 am
K&N are expensive when you have to buy two.But are worth every dollar :D
Will the subs fit 1 1/34?
PostPosted: Fri Apr 04, 2008 8:21 am
Give Ash some flowers Nick .
They are worth it IMHO. I run K&N filters with Kev's stubstacks for that bit of extra bling 8)
PostPosted: Fri Apr 04, 2008 10:02 am
I don't make them for HS6 or HIF44, with those it's easier to stick the carby in a lathe and machine a radius in it.
PostPosted: Fri Apr 04, 2008 5:18 pm
minimatt
thanks for the info
are you able to post a pic of your set up
Doc
I was also thinking of the stubs
If i fit them later one will it effect my needle choice
Kiwinwgtn
PostPosted: Fri Apr 04, 2008 6:11 pm
kiwiinwgtn wrote:
Doc
Kiwinwgtn
No, it made no real difference mixture wise to my wife's car, I'm still using #6 needles in it. But it's got better throttle response and more top end. 8)
PostPosted: Sun Apr 06, 2008 8:45 pm
Doc
just been thinking and making up some card board templates to see if those K&N filter fit is why do not turn a radis on 1.5 inch carbs like you do the 1.75 inch
PostPosted: Sun Apr 06, 2008 9:10 pm
Discussion-
Well you could do that I guess, but I only have a small bench lathe... I would have to make tooling up to hold it-and after you put a radius in the carb mouth, you then have to cut the hole in the backplate bigger to clear the radius, etc etc......
I just let GR machine the 1-3/4 carbs. :wink: `
OTOH, these HS2 and HS4 stubstacks are a development of the Weber & Dellorto ones I already make from 65mm alloy bar.
Making HS6 or HIF44 ones I would need much bigger bar, and have lots of waste, so they would cost more.
PostPosted: Sun Apr 06, 2008 10:23 pm
Here is my setup - as bought off eBay not yet overhauled...
Filters backing put loosely in place (too cold to go and find bolts in the garage ;-) )
A close fit but do fit... otherwise when fitted will look similar to other pictures posted in the thread (though they are using maniflow manifold)
PostPosted: Mon Apr 07, 2008 8:50 am
really nice looking set, don't look like they have done much work, But then a bit of spit shine goes alongway.
*Reasonable pricing
*I come to you..
Jay: 0431404607
Users browsing this forum: No registered users and 321 guests
