It is currently Wed Jul 30, 2025 6:45 am
PostPosted: Tue Apr 08, 2008 5:20 pm
310lb = 140kg. That sounds a bit light but the early Mini bodies were stamped out of thinner sheet. That weight may also be without primer/paint, under-seal, etc. Then add some brackets and things and some wiring and it could be up to about 200kg. That sounds about right.
I have a few different books that give the weight of the complete power unit around 155kg
One book lists....
engine (1275) = 115kg
gearbox = 31kg
complete power unit = 154kg
engine (1100) = 111.13kg
auto transmission = 50.8kg
PostPosted: Wed Apr 09, 2008 10:46 am
My stripped bare 850 shell weighed in at 132kgs. We weighed it at the local scrap metal place.
PostPosted: Wed Apr 09, 2008 1:31 pm
Yep, 310lb is right. Not for a later shell with additional seat belt strength and certainly not for a Rover shell with all the additional brackets.
The glass weighs a lot and so do doors. I have a very thin front windscreen in my spares pile. I'll never use it because it is toughened, not laminated but it is far lighter than the later windscreens. maybe a racer after extreme lightness but constrained to use glass may want it.
The engine weight I posted was measured with a calibrated load cell. It didn't include exhaust/inlet manifold, alternator, radiator or fluids. It had a rod-change box. Add in the bits not attached and you'll get the 154 kg listed above.
That cutting I posted was from an article in "Automobile Engineer" from 1959. The same article is full of tech data, like that torsional rigidity value also in the cutting.
M
PostPosted: Wed Apr 09, 2008 2:12 pm
Would most definitely have to be a laminated screen if being used in a race car :wink:
PostPosted: Wed Apr 09, 2008 2:22 pm
Well, it's an awkward paper weight then...
PostPosted: Wed Apr 09, 2008 5:28 pm
M
I have just looked through an old manual and it also gives the 310lb weight for the sedan and also gives 420lbs for the estate and van body. The weight of the body with subframes is given as 435lb for the sedan and 545lb for the van.
This book also gives the "Weight of engine (dry)" 308lb (139kg)
Thinking about it the weight for the engine that I quoted must be a complete "wet" weight. I should know this because I can lift an engine and gearbox (without manifolds, radiator, alternator, starter and oil) I don't think I would be able to lift 150kg. :lol:
PostPosted: Wed Apr 09, 2008 9:55 pm
Who's going to post the weights of the slidy and windy (Aus) doors for us all??
Users browsing this forum: Bing [Bot] and 93 guests
