It is currently Sat Jul 19, 2025 8:53 am
 Post subject: Vinly cleaner
PostPosted: Wed Jan 19, 2005 12:56 pm
What is the best product to clean very old and dirty vinyl with?
PostPosted: Wed Jan 19, 2005 1:17 pm
Vinyl Cleaner :wink:
David L
PostPosted: Wed Jan 19, 2005 1:27 pm
SECOND THAT
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Wed Jan 19, 2005 1:48 pm
Try Dissol, worked a treat on Charli the Traveller. Very cheap too
1965 Morris Mini 'Woody' Traveller
PostPosted: Wed Jan 19, 2005 3:38 pm
geee, i wonder what car will be geting
its vinyl cleaned..... :roll: just rub it in (get it)
lol, i take it you will be sprucing up pops this arvo...
PostPosted: Wed Jan 19, 2005 5:23 pm
anton if it is really old and warn it probably wont look much cleaner no matter what you do. Id get a spray on degreser onto it (not in the sun) do alittle bit at a time. spray it on, rub gently with one of them green scourers., then wipe clean with a rag,.
1974 Moke - 998cc
PostPosted: Wed Jan 19, 2005 5:25 pm
as 13 said then maguires vinyl restorer to give back a little moisture.
aaron
 Post subject: mini
PostPosted: Wed Jan 19, 2005 5:29 pm
I used dissol on the moke seats, which came up a treat!
PostPosted: Wed Jan 19, 2005 5:36 pm
if u can get ur hands on it try get some "zoff"
if they're not leather seats (which they aren't) then go for it.
PostPosted: Wed Jan 19, 2005 7:25 pm
i tried all the vinyl cleaners n shiet
they are good for clean vinyl
so for my seats steve used Gumption
and i used Ajax, or Jiff
these all are abrasive cleaners they will get all the dirt
use with plenty of water and a green pan scourer
dont worry no harm to the seats
after protect with a protector eg meguires vinyl shine
all this i learnt in one afternoon at stevenmikeys place
Inconspicuously Conspicuous
PostPosted: Wed Jan 19, 2005 9:09 pm
hmmmm....thanx all for the tips.
Pops vinyl is immac, except for 34 years of bums rubbing dirt into the it. If I can get a good cleaner they should look new. None of the vinyl has gone hard from the sun, or faded....it's been garaged all it's life!
Where do you get Dissol from and what exactly is it? Is it automotive or household?
 Post subject: Gumption
PostPosted: Thu Jan 20, 2005 8:31 am
Anton
I promise 20 minutes and the seats will look like new if you take a green scouring pad wet it good dip in a little gumption and wipe of dirt and excess moisture with a clean cloth and they will be like new, promise. same goes for the door cards.
Steve
PostPosted: Thu Jan 20, 2005 12:39 pm
well I am going to try it out right now!
You know me....I'll wack some pics up of the results.
Cheers.
PostPosted: Thu Jan 20, 2005 8:16 pm
well I combined suggestions from here and suggestions from my trimmer and ended up using Sunlight soap and a green scotchbrite pad.
This is how they came up...one cleaned, one dirty.
Thanks for the tips fella's.
PostPosted: Thu Jan 20, 2005 8:19 pm
not bad mate, looks 100% better.
you can always get some vinyl paint and really cover them up :D
1974 Moke - 998cc
